Old 08-17-2015, 09:29 PM   #21
When in storage I use the reflective insulation on each window. Can be purchased at Home depot or Lowes. Cut to fit. It also works on the bathroom clear skylight.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 08-17-2015, 09:45 PM   #22
speedcat's Avatar
Down while in storage and mostly down when camping unless the view dictates otherwise. Up while traveling to keep them from bouncing the strings loose.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 08-17-2015, 09:51 PM   #23
mark0224's Avatar
For winter I put them up and got a roll of (Shop Reflectix R21 48-in x 25-ft Unfaced Reflective Roll Insulation at Lowes.com) and cut pieces to the size of each window then pulled the blind down to hold it in place. Keeps sun out and protects shades.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 08-18-2015, 07:27 AM   #24
Wolverine 1945's Avatar
I have made window covers out of cardboard,,, we place them in every window when we are not using MH,,, even the windows in the cab !!! We then pull the shads down part way to hold cardboard,,, just last week I painted then all white on one side !!!
Remember,,, dark is COOL !!! Even in our homes !!!
I do think I like the Idea of painting Sky Lights !!! Krylon Fusion ???
Wolverine 1945 is offline   Reply With Quote
Old 08-21-2015, 08:55 PM   #25
To UV or not?
Originally Posted by Loneeagle View Post
I've heard different answers on this, but what's the consensus on whether to leave shades up or down during winter storage?
Thanks.
It depends n where you store it, and also a big thing most here have not mentioned (which windows do you have) in my cedar creek it has the dark tint windows and they stop most if not all fading issue.
So if you live in the southeast no matter what windows I would close the blinds, but if not you can leave the open if you have the dark tint windows.
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 08-22-2015, 06:30 AM   #26
Originally Posted by Jane1550 View Post
A trick we found with the pleated shades when they begin to loose their shape is to spray laundry starch on them then leave them folded for a bit...viola!!! good as new...
Wonder if that would work on the pleated shade that is on the sunroof ???
Old 08-22-2015, 06:35 AM   #27
Why would you ever leave the shades up,,, unless it was to protect them ???
Old 08-22-2015, 06:53 AM   #28
dj3spots's Avatar
Shades down definitely - helps with UV protection and a little security to keep anyone from seeing what's inside.
dj3spots is offline   Reply With Quote
