Old 04-29-2013, 09:09 PM   #1
shake-down
Took our shake-down run this weekend and really went well! Couple of newbie dahs but figured them out. Got a couple of questions 1. We have the jensen system with cd/dvd player with the usb connection. Can you play movies through the usb port from a hard drive? 2. Can the tv be lifted off the mount and moved to bedroom(bracket installed overhead from factory)if so how? thanks
bandit9077 is offline   Reply With Quote
Old 05-02-2013, 11:50 AM   #2
tanddc's Avatar
I am not sure but it could depend on the file type. If it can, plug into the USB, and it should go to the USB mode (if not, just hit the mode button). It will take a while to read index your drive (the more you have on there the longer it will take) and then you will see whats availible on the TV screen (assuming you have set the right mode on it). At the bottom of the screen you should see choices for music, pictures, and movies. Scroll down to the movies and hit the button. Everything availible will then be on the side menu.
tanddc is offline   Reply With Quote
Old 05-02-2013, 01:34 PM   #3
thanks, must not have waited long enough. Not very computer savy just an old gezzer.
