Old 08-07-2011, 05:11 PM   #1
funseeker's Avatar
Slideouts on 2010 Sunseeker
Can anyone tell me how to manually retract the bedroom and dinette slideouts without power.
funseeker is offline   Reply With Quote
Old 08-07-2011, 07:03 PM   #2
BOBFIDY's Avatar
The slide outs on our trailer have a small hole on the oppisite side for using a socket to hand crank the slide in. Have not had to use it YET.....but I'm thinking they are mostly all the same.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 08-07-2011, 07:20 PM   #3
GM
bclemens's Avatar
The dinette slide has a shaft sticking down below the slide out (when the room is in). It is typically in the roof of one of the storage compartments below the slide. Pull the cotter pin, put a ratchet on it and start cranking..
I the bedroom slide, that slide motor I think is turned UP, so you need to life the bed and possibly pull off the paneling that covers that area...same thing, ratchet it in.
If however you have the newer "schwintec" slide (bedroom slide will have (4) metal tracks on the slide room walls) the you cut power to the system and push the room back in manually.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 08-07-2011, 07:21 PM   #4
Boyd's Avatar
Your Sunseeker looks like my 2010 Freelander Dreamer. The manual crank for the slide can be found (on mine) in the bin/hold next to the propane, second door on drivers side. On the top of the compartment you'll find a shroud held on with four screws. Drop the shroud and that will expose the slide motor. You'll see a nut, 5/8 or 9/16 I think, on the box that the motor is attached to...That is the Manual Override. You find it pictured here
http://www.eco-rv.com/scripts/pdfretail/get.php?id=365
"If everything seems to be going well, look around, you've obviously overlooked something."
Boyd is offline   Reply With Quote
Old 08-07-2011, 07:22 PM   #5
GM
bclemens's Avatar
PS. Lippert is the company that builds that Schwintec "in-wall" slide, they have some videos on their website with troubleshooting instructions. I haven't looked, but they they may have something on the floor ram slide as well.
