Not rivets, but special nuts.
To install the carrier two M10X1.5 special die-cast aluminum nuts (Ford part number W703095S450) and two flanged hex head M10X1.5 - 25 MM long screws (Ford part number W500633S442) needed. The hex head screws are not any special, other than they are flanged, regular hex head screws with washer can be used. Those nuts have a hex on the outside that fits in the chassis' hex holes. After nut is inserted and screw is tightened the front part of the nut (between nut’s flange and the inside thread) gets crashed and nut now stays in place even if screw will be removed. Loctite compound to be used on those screws (they are not tightened to a high torque as they are Aluminum). The muffler holding bracket is mounted in the same way. The Anchor Plate has to be attached to the rim with two M12X1.75 nuts from the side of the rim opposite to the one where the nipple is. (Even in some places it says directly opposite. I tried – if it’s done this way the Anchor Plate will hit the chassis’ bracket and carrier conduit’s end fitting before the wheel is lifted in place and you’ll end up with the wheel not pulled tight against the frame, but freely swinging. Also Anchor Plate is too long and does not fit inside of that offset flat to the rim’s surface.) So in case with dual rear wheels’ rims that have big offset that offset should be down. And the wheel should be mounted with the nipple down. As you see on the pictures the Anchor Plate has a recess to fit the rim’s profile. The Anchor Plate is common for all Ford Transit models, so I believe the wheel should be hung with offset down no matter if it’s dual wheel rim or not, but that’s my assumption. In case of RV chassis I do not think a single wheels on the rear axle are used in any Transit based RV model. Cable in conduit that comes out of winch makes a 90 degree bend and fits (snaps) with it’s end fitting in chassis’ bracket. To raise and lower the spare I use 8” long ½” square extension . I’m thinking to make 27MM hole in the outside wall of the RV right behind the rear wheel in line with the carrier access whole in the chassis. If I inset 7/8” PVC pipe (~26.6MM OD) through that whole as well as through the access hole in the outside wall of chassis all the way to the carrier I’ll protect the carrier socket from the road dirt and with a long extension I’ll be able to lower the spare with no obstructions standing next to the rear wheel. Right now I have to do it from the rear wheel's well, that's not convenient. It’ll be necessary to go under the rig to unhook the cable anyway, but at least it’ll be easy and convenient to turn the winch. And from the outside I’ll plug that access pipe with a decorative plug. But that is not done yet.
Severin & Ellen
1991 Westfalia Vanagon GL full camper
1997 Eurovan full camper
1984 Catalina 36 hull 268 (sailboat)
2017 Coachmen Freelander Micro 20CB
Ford Transit 350 HD cutaway chassis.
