Old 05-31-2018, 01:48 PM   #1
Squeaky...
Hi, Just purchased a 2019 Cherokee 234 VFK; have an issue and am looking for advice. When I towed it at slow speeds coming home, I noticed a loud squeak from somewhere behind me. Called the dealer, and was told I should use Silicon on the ball and arms of the sway hitch. ( and never use grease).
I did notice some of the chrome rubbed off the tow ball; any thing to that? What does every body use to lube their system?
Thanks!
rennzfr
Renn and Gail
98 Expedition, 3.73 gearing, auto with overdrive,
with Airlift 1000 shocks, 107,000 original miles,
Factory tow package and brake controller added.
Rennzfr is offline   Reply With Quote
Old 05-31-2018, 01:54 PM   #2
5Kins's Avatar
My dealer rubbers Lukas wheel bearing grease on my ball at purchase.
5Kins is offline   Reply With Quote
Old 06-01-2018, 10:56 AM   #3
What type of WD hitch do you have?
Fireguy205 is offline   Reply With Quote
Old 06-01-2018, 11:04 AM   #4
jeff64's Avatar
You probably have the Equalizer WDH. Good hitch, but, they do make noise and need to be greased periodically
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 06-01-2018, 03:38 PM   #5
Sqeaky Hitch
It's a Sway Control by Tuff Tow.
Old 06-01-2018, 04:52 PM   #6
I would definetly grease up the ball that should make a huge difference.
Old 06-01-2018, 06:46 PM   #7
Sqeaky Hitch?
Well, just lubed it and drove around a bit; yes the metal on metal sounds are gone (thank you) but it squeaks alot over speed bumps, driveways. Is that normal? Should I be looking for Zerk fittings?
Thanks all!
Old 06-01-2018, 07:54 PM   #8
I don't believe there are any Zerks. I have the equalizer e4 WD hitch so mine is different from yours. When I get noise from mine I lube the ball and a couple spots where my bars connect to the hitch. Maybee you could try and lube where your bars connect to the hitch.
Old 06-01-2018, 10:14 PM   #9
Are you sure it is coming from the hitch? I use lithium grease on the ball or any kind of tube grease just cause it is easier to put on. On the equalizer I use "On The Ball" oil which is a high weight oil made specifically for hitches and levelers.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 06-02-2018, 11:37 PM   #10
The sounds from the hitch are gone, I think it's the axle area; noisy going over bumps and driveways. Springs maybe need lubricated?
Thx
