02-16-2014, 06:53 PM
Stabilizing issues
We have a 26RL Forrest River Cherokee Grey Wolf. It's a 2012. We are currently parked on concrete and using cinder blocks under the remote stabilizers and front hitch. The trailer shakes and moves like it hasn't been stabilized at all. I'm at my wits end. This thing rocks when you get inside, when you walk around, roll around in the bed at night, or literally move a muscle. I'm sick of it!
We are new to RV lifestyle though and haven't found our niche. What do I need to purchase or do to get this thing to stop rocking?
02-16-2014, 07:06 PM
Have you tried Xchocks between the tires.
They work real good for us.
Eggs
02-16-2014, 07:12 PM
No I haven't. Where would I buy them?
02-16-2014, 07:16 PM
Get a set of four like these.
Camco Trailer Stabilizer Jack Stands 4/Box (44560) - R V Accessories - Ace Hardware
Put two in front of the front axle and two behind the back axle.
Do NOT lift the unit off the ground.
02-16-2014, 07:18 PM
Amazon, camper world, any rv deler if ther have supplies. Maybe wally world.
They do help quite a bit. Also discovered this last summer of you can get something under the steps to support them, that really helps the entrance, exit.
I also use a tripod under the pin, if i am going to stay somepace for more than a day or two.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
02-16-2014, 07:21 PM
Got mine from my dealer , but any rv accessories shop have them.
Cost is around 50$ Canadian for a pair.
Hope this helps.
Eggs
02-16-2014, 07:23 PM
Originally Posted by Ford Idaho
2 scissor jacks in front of the front axle with U welded to them and bolted to the 2 x 4 frame works great also and you can use a cordless drill to run them up and down.
02-16-2014, 07:29 PM
X Chocks do work well. You can find them at Camping World, your local RV supplier, on line etc..Price range is typically $70-$100 and if you shop around you may find them between $50-$60. However, I will say you will not eliminate all movement. There are many threads of discussion about stabilization and multiple methods. Despite some movement the RV lifestyle is well worth it!
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
02-16-2014, 08:18 PM
The drop down 'stabilizers' are more for show on my unit. The do not work all that well. I have the x-chocks and they help.....To get the job done. Get a pair of scissor for the front and a pair for the back to have real stabilization of your unit.
24" Scissor Jacks - Two jacks with handle - Stromberg Carlson JSC-24 - Stabilizing Jacks - Camping World
I also use the 'save a jack' quick disconnect as the skirts on the sides of my unit hang way down and I can not crank my scissor jacks all the way up.
Brother Les
02-16-2014, 08:24 PM
I use x chocks, bal lock arms on the scissor jacks and the camco stabilizer jacks and they all work great together.
02-17-2014, 11:17 PM
all these tips will help remove some of the bounce but do not expect you trailer to be as sturdy as a house. As they are designed to be mobile there is just to much flex in the frame and structure. This has to be there or your trailer would break apart on the highways.
Rockwood 8293RKSS
02-17-2014, 11:52 PM
Note: the X-chocks, or any other between the tire style, will help with front to back stabilization only. If you have the power stabilizers, like I have, they help with side to side stabilization. For those, I've found the less they're put down, the better they are at stabilizing. You said you've already get them on cinder blocks. Do you have room to go 2 high? Or to add some 2x whatever planks? It made a world of difference in our TT to only drop them ~4 inches instead of the 10-12 I had been putting them down.
02-18-2014, 12:45 AM
TeresaInCAL
There also is a step stabilizer, looks kind of like a kickstand for your step, should be under 20 bucks. I just got one, haven't installed it yet.
Teresa
2013 f150 Ecoboost 4x4
2009 Gray Wolf, 22BH
02-18-2014, 07:29 AM
I had one commissioned by oc.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
02-18-2014, 07:35 AM
Originally Posted by f1100turbo
I had one commissioned by oc.TURBS
Slight correction, that was Ms. Amy's Christmas present/condolence gift for tolerating FT Turbs.
02-18-2014, 07:48 AM
Point taken!
TURBS
02-18-2014, 07:51 AM
Point taken!
Thus the name (Forked Tongue) FT Turbs.
02-18-2014, 08:12 AM
Or Car jack. Youroo!!
02-22-2014, 03:48 AM
Plug It Right
You might also think about adding aftermarket permanently installed stabilizers. We did 8 years ago and would n-e-v-e-r be without them again. Mamma is a happy camper and you know what happens when Mamma's a happy camper, right??
They are also a boon in the wind and we don't have to put anything up, take down or find a place to store out old Bi-Pod.
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.
02-22-2014, 04:42 AM
Amazon has a good price (and you need to buy a pair - one for each side)
Amazon.com: BAL 28012 X-Chock Tire Locking Chock: Automotive
That takes Care of your Front-to-rear Rocking & Swaying. For Side to side, get three sets of these:
Amazon.com: BAL 23216 Lock-Arm Stabilizing Bar: Automotive
Finally, talk to OC (Old Coot) and get his step stabilizer mod and you will be just about as rock solid as a 4 point jacked Class A!
P.S. If you are not a AmazonPrime member, go ahead and join - well worth the $79 - especially if you like to watch movies!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
