Old 09-15-2017, 12:02 PM   #1
Frank & Eve's Avatar
Stained 3m Protection Film
Any of you know what to do about this problem? Have scrubbed with everything. Looks like it's mold under the film.Click image for larger version
ID:	151495Click image for larger version
ID:	151496Click image for larger version
Frank & Eve is offline   Reply With Quote
Old 09-15-2017, 02:43 PM   #2
A32Deuce's Avatar
That is mold underneath. I have seen it before. Have to remove old and buff it out and put down new.
A32Deuce is offline   Reply With Quote
Old 09-15-2017, 05:28 PM   #3
Ok so this afternoon we started the removal. Started with heat gun and plastic razor blades. This is no easy task. DH started just slicing the film underneath and pulling it back as he went. Gave up on the heat gun. As he was slicing and pulling I was applying Goo Gone. Spray well and rub in let set a while then scraped the glue off with plastic razer blade. About 4 hrs later we finished the hood and the fender pieces. Still have that large piece on the cab. I will be calling a body shop to remove it!
Old 01-16-2018, 05:09 PM   #4
Joelhughes's Avatar
Did you ever finish this? I've got this problem as well. Problem is that my whole trailer is wrapped. I'd have to try and cut out a section. Good luck finding replacement wrap for that section
Joelhughes is offline   Reply With Quote
