10-20-2018, 08:27 PM
Take it easy,but take it
storage of sway control bars
Any thoughts on a storage spot for my sway control bars ? I grease them on the contact areas..I am storing them in my front compartment--Is a greasy mess in there. Can i weld a pipe on the frame and set them in it out of the way ? Nick
10-20-2018, 09:09 PM
Mine are in my hollow rear bumper when not in use.
-- Chuck
10-20-2018, 09:12 PM
My wife took a pair of my old Levis, cut the legs off, sewed one end shut. I just slip one over each greasy end and store in the front compartment. Been working great for the last year.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
10-20-2018, 09:36 PM
I bought a cheap nylon rifle case and store mine in that then put the whole thing in pass-thru storage.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
10-20-2018, 09:59 PM
I did a variation of the fence post sewer mod using 2" PVC pipe. The pipe is 8 ft long, hung under the frame. I insert one bar in each end.
2011 Traverse LT, 3.6L, FWD
10-20-2018, 10:06 PM
I just stick the greasy ends in poop bags [emoji16]
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
10-20-2018, 10:12 PM
I used to just balance mine across the battery storage box.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
10-20-2018, 10:14 PM
I store the sway/weight distribution bars in the front side storage compartment of my 2016 2504s Rockwood.
Check the manual for your hitch - my hitch instructions explicitly state not to lubricate the bars at the sliding point of contact with the L-brackets attached to the trailer frame (e2 hitch system). --Ray
10-20-2018, 10:24 PM
Really ? I had better do some checking---i have always lubed them for wear and noise-will check again Thanks--making this more difficult that need be !
10-20-2018, 10:27 PM
There are times when the road has some sharp switchbacks,and sharp turns into camp spots--i do this with the bars removed--need a spot to store them without loosing them ! Thanks Nick
10-20-2018, 10:28 PM
I just (finally) lubed the L part on my e2 that gets inserted at the vehicle side and I’m floored how much quieter it is. But no, never lube the flat contact parts!
Carmen and the pack
10-20-2018, 10:53 PM
If you have sway bars with chains like the bars I had on the travel trailer maybe you could adjust the angle so the chain ends are lower and lengthen the chain? That way you will have a little more room for sharp turns. I never had an issue with mine making sharp turns or backing into a tight campsite.
10-21-2018, 12:13 PM
Ok I have not been told to grease my bars do I grease both end of bars
10-21-2018, 12:32 PM
From my Equalizer owners manual (emphasis added):
In some cases the friction on the L-brackets can generate noise. Lubricating this joint is not recommended. A better solution is a set of official Equalizer brand Sway Bracket Jackets™. They quiet the ride and reduce wear without the mess of using a lubricant.
Just a recommendation, not a prohibition.
-- Chuck
10-21-2018, 12:43 PM
I know this is not exactly on topic but these help with some of the noise from the bars riding on the L brackets. Do not lubricate where the bars ride on the L brackets. These can be found at many places besides etrailer, it was just the first ne that popped up on my search.
https://www.etrailer.com/Accessories...SABEgLLifD_BwE
2018 PUMA 31 BHSS
2017 RAM 2500 LARAMIE 6.4 HEMI 4X4
E2 WDH
Troy, Josie and our 2 K9 co-pilots Breck and Maggie
USN 86-92
3 nights camped so far in 2020
10-21-2018, 12:52 PM
10-21-2018, 12:55 PM
Get yourself some military style sand bags and slip the greasy ends into the sand bags and store them where you do now.
2016 Salem 27RKSS
I just had someone tell me that the friction at the L bracket is designed in to act as sway control, hence the prohibition of lubrication. This sounds ridiculous to me, what about others?
10-21-2018, 01:21 PM
Trailer Park Supervisor
John, that is a slick little compartment you built! What is just to the left? Blocks?
Yes, I drink the water!
10-21-2018, 01:23 PM
Per the Equal-i-zer owners manual:
Proper weight distribution also adds performance to the Integrated Sway
Control™ (ISC) feature of your Equal-i-zer® hitch. As the tongue weight
gets distributed, it helps generate the friction needed to reduce trailer sway.
Sway Control:
ISC is a built-in, patent pending feature of your Equal-i-zer hitch. Once
the spring arms are tensioned, the sway control is in force.
ISC works through the connection between your spring arms and L-brackets, and between the sockets and hitch head. The Equal-i-zer hitch takes advantage of the steel-on-steel friction generated at these points to help reduce trailer sway.
This added friction makes it much more difficult for the trailer to sway
side-to-side while its being towed, as sometimes happens when you encounter a gust of wind or a passing semi. When set up well and properly adjusted
for your load, the Equal-i-zer will noticeably reduce sway.
