Old 03-16-2016, 02:07 PM   #1
Storing RV in FL summer
We are storing the RV in FL, using a custom cover, but would like to know any hot weather tips, to prepare it.
Ever heard of putting water in the toilet bowl and covering with saran wrap? Would this save the seal over summer time?
Dianizon
dianizon is offline   Reply With Quote
Old 03-16-2016, 02:23 PM   #2
Kels4g's Avatar
I would make sure to clean it completely leaving not a morsel of anything with a scent ie, cleaning products, deodorants and other hygiene items, food.
Also remove any paper or cardboard items as these can attract roaches and other bugs.
Kelly and Stephen with Daisy, Lily, and Roxy!
Run Free Sweet Riley 2009-2015
Visit our blog for more information and details!
www.kels4g.com
Kels4g is offline   Reply With Quote
Old 03-16-2016, 02:28 PM   #3
A dehumidifer is a must for a Florida summer.
Kevin & Judy is offline   Reply With Quote
Old 03-16-2016, 02:50 PM   #4
Bug bomb, big bucket of Damp-Rid, remove all food, drain you fresh water tank and heater. If you had power leave vents open (max-air or similar) and put a small fan on a timer inside. I've done this on covered boats and campers and it really helps to keep the heat down inside. I just leave water in the toilet bowl.
2016 Wildwood 32BHDS
2004 F-250 CC 4X4 V10
Mars is offline   Reply With Quote
Old 03-16-2016, 02:55 PM   #5
Bluepill's Avatar
Obvious, I know, but try to find a shady spot. I don't worry about bugs or small animals because they will die from the heat.
Cover the fridge vent on the exterior with saran wrap, etc.
Old 03-16-2016, 03:33 PM   #6
If you are storing where there is electricity I would leave the ACs on set to 84 F.
whj77372 is offline   Reply With Quote
Old 03-16-2016, 07:27 PM   #7
We keep the unit plugged in to a regular 15amp plug so I can run the Max Air fans. I have them set to come on at 82 and go off when cooler. I also keep the ceiling fan on to keep air circulating. I have 3 large Damp Rids in the unit and check them weekly and a drain any fluid. All food out, a febreeze deodorizer on the kitchen counter as well. I also have my bug guy keep it sprayed inside and out.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 03-17-2016, 06:27 AM   #8
Heat and humidity you have to love them!! If your vent stacks are under the cover the moisture in the tanks will not only stink to high heaven in the heat but will raise the humidity to even higher levels. I don't know how to use damp rid but our friends had a huge mess with the bucket overflowing while in storage causing a lot of floor damage. Make sure you understand how to use it and talk to others who have.
We are trying a dehumidifier with outside drain like another couple we know uses. I think that is the best if you have electricity in storage.
Also, put something under the tires.
N. Brevard County, Florida
2010 Lexington 255 GTS
2000 Jeep Cherokee Toad
dontay is offline   Reply With Quote
Old 03-17-2016, 06:56 AM   #9
Dave Lyon's Avatar
WRT the toilet. I would forego the saran wrap. It would cause a lot of mold underneath it. I would wipe the toilet seal down with a light coating of dielectric grease or vegetable oil and leave the bowl empty.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 03-17-2016, 11:23 AM   #10
Thetford makes a blue colored seal protector and lube. Pour a little in the toilet when you store it. It'll keep the seal from drying out and leaking.
David and Vicki
8 year old Springer rescue Sydney
2018 Silverado LTZ 3500HD Dually Crew Cab Duramax/Allison stock "Polar Bear"
2019 Grand Design Reflection 337RLS "The Dog House II"
Andersen Ultimate 5th wheel hitch
EezTire TPMS
Springerdad is offline   Reply With Quote
Old 03-17-2016, 12:44 PM   #11
I have a spray can of rubber seal protectant which I use on all seals including toilet keeps them soft and pliable. No problems yet.
Myrle is offline   Reply With Quote
Old 03-17-2016, 01:00 PM   #12
Don't Camp Enough
DSMURPHY's Avatar
x2
'2016 Rockwood 8288WSA
'2016 F-350
DSMURPHY is offline   Reply With Quote
Old 03-17-2016, 01:04 PM   #13
If you can afford covered storage, not just a cover, DO IT.
RV covers don't lsst very long in South Florida. Do both of you can.
Old 03-17-2016, 03:07 PM   #14
Small Animals
I live in South Florida and I use Damp Rid inside several places in the cabin and I do worry about small animals. They love the heat and will chew on your wires. I keep d-Con in a couple of places inside the RV frame but outside the cabin. One next to the engine and one near the rear of the camper.
hikerjohn7 is offline   Reply With Quote
Old 03-17-2016, 03:35 PM   #15
7 Year Class A RV'er
We live in Orlando and keep our coach in the drive, plugged in and the AC on year round. Probably not feasible in your case, but it sure is nice to not have to worry about it. I can tell you to make sure you don't have any limbs or vines touching it at any point and to protect the cords if you do have it plugged in. Ants WILL get inside regardless if there is path for them. Also, be very careful when you get into the battery compartment at the end of the summer as the fire ants just love to nest in the areas around the warm batteries (assuming they have a trickle charge to keep them up). The UV here will kill you worse than the heat, but I would still heed what some of the others have said about keeping air flowing through the coach if at all possible. IMHO, fresh flowing humid air is much better than hot stagnant humid air.
2015 Legacy SR340 360RB
Old 03-17-2016, 03:37 PM   #16
Forgot to mention another option you may be interested in. I have no idea what the cost is, but there is a company that just relocated to Daytona Beach called Classic Coach Works. They do coach renovation, etc. Very nice folks. Their new facility has inside RV storage. Might check with them and see. Definitely better than leaving it out in the weather and there's always someone there to watch things for you.
Old 03-17-2016, 06:02 PM   #17
Spray bug killer around the tires and anything else that contacts the ground.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 03-17-2016, 07:52 PM   #18
V-Lite Fun's Avatar
I live in Florida year round. I put a large damp rid inside. Remove all food items. Before I park my trailer I spray Termador on the ground my trailer will be parked on. Never ever have a bug that way. I park on wood planks. Cover the wheels and put a cover on the trailer. Never have any issues. Mine sits for several months at a time. No problems with anything.
Forest River Flagstaff V-Lite 26 WRB. 2015 Ford F 250 diesel, Hensley Arrow Hitch
http://rvadventuresofpetedoll.blogspot.com
V-Lite Fun is offline   Reply With Quote
Old 03-21-2016, 06:09 PM   #19
TsnTexas's Avatar
I've seen a couple comments in this thread about DeHumidifiers and wonder if anyone can recommend a good one? The smaller the better.
TsnTexas is offline   Reply With Quote
