Old 01-31-2018, 09:40 PM   #1
Surge Protector?
Just bought my first TT, Grey Wolf 26DBH. Do I need to purchase a surge protector? 30 amp power. If I do, any worries about theft....seems like anyone could unplug a $200 one and just walk. Looking for recommendations for need, brand, and security. Thanks.
Nights Camping:
2018 - 44
avigator is offline   Reply With Quote
Old 01-31-2018, 10:23 PM   #2
2018 Rockwood 2703WS
Houston Remodeler's Avatar
After too much research, we installed a Progressive Industries hard wired unit with the display.
1- My memory is so crappy I would have left the plug-in one behind eventually.
2- It has saved our coach many times.
3- I like the on / off switch for when we use our generator
4- The display tells us by a code, what the problem is / was.
2014 Ram 2500 4x4 diesel
guarded by our Jack Russell
Houston Remodeler is offline   Reply With Quote
Old 01-31-2018, 10:32 PM   #3
FR27's Avatar
Yes, you need one if you want to protect your electronics. I've always installed an internal one from Progressive Industries, so no one can mess with or steal an external one. Also, with the internal surge protectors you don't have to mess around with something else to plug in when you get to your site.
FR27 is offline   Reply With Quote
Old 01-31-2018, 10:34 PM   #4
SailorSam20500's Avatar
X2, and I agree with the comment about not being able to forget it!!!
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-31-2018, 10:51 PM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
X11
Pay me now or pay me later and cry.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 01-31-2018, 11:39 PM   #6
Fulltime family RVer
All of those answered and more:
What Surge Protector is best for my RV? | Learn To RV
ependydad is online now   Reply With Quote
Old 02-01-2018, 09:35 AM   #7
Add up what it'll cost to replace all your on board electronics : fridge, tv, microwave, water heater, AC, furnace, etc. Then you make the decision. Progressive Industries is the brand of choice here. Go with an EMS unit, so much more that just a surge protector. Link: Progressive Industries, Inc. | Rv Surge Protection
Old 02-02-2018, 09:25 AM   #8
I bought the same camper. I installed the Progressive EMS-HW30. I purchased from Amazon for $240. I bought that one for the exact reasons you mentioned. I didn't want to have it stolen or left behind. I like that the display tells you how much power you're using and that it cuts power in a low voltage situation (saving a/c unit from damage). Install was easy. The unit is mounted under the bunks in the back and I put the remote display right above the thermostat. I'll post pictures of the installation when I get a chance this evening.
Mmcglynn264 is offline   Reply With Quote
Old 02-03-2018, 11:32 AM   #9
paulmac's Avatar
Yes, well worth the money. We never had one and started using 1 last season. First evening we used it all the power went off to the coach. Went outside to check on it, thought for sure something was wrong with the device as power was on outside, noticed other campers having no problems. Turns out the voltage had dropped causing the device to turn power off based on the error code. Once voltage was returned to a safe level it restored the power to the coach. We were running our AC so the low voltage could have done damage to the compressor if the surge protector had not worked. As far as theft goes the device we have allows you to lock it to the pedestal or power box with a small loop of chain and a pad lock. I have never actually locked it down, but I can if I want to.
paulmac is offline   Reply With Quote
Old 02-03-2018, 11:36 AM   #10
davel1971's Avatar
Another vote for Progressive Industries EMS hardwired unit. Mine saves me a couple times a year from something. It's always there, so it's always working.
David & Lynn
Old 02-04-2018, 08:11 PM   #11
How DIY friendly is the installation on something like this? I have mild knowledge with electronics.
bclinton is offline   Reply With Quote
Old 02-04-2018, 11:22 PM   #12
I thought the installation was pretty straight forward. Working with 10 gage wire isn't easy - the stuff is stiff. I installed my unit behind the power panel/converter. That meant a bit of contortionist bending. I did not cut any wires. Rather I pulled the main feed off of the power panel and put it on the input side of the EMS. I bought a short section of wire that I used to go from the output of the EMS back onto the input of the power panel (main breaker).
You can find all of the install manuals at: Progressive Industries, Inc. | Rv Surge Protection
Al
S.E. Mich.
Old 03-06-2018, 11:12 AM   #13
My EMS-HW30 install (including remote display) 2018 26DBH
I just removed wires from back of trailer's receptacle, connected them to surge protector then used small length of 10/2 wire to connect from surge to back of receptacle. All was accessable by removing plywood from bottom bunk. I then made a whole in wood paneling under bunk and fished display wire up and out by thermostat. Works perfectly. Surge can also be accessed through rear storage hatch.
ID:	164412   Click image for larger version
ID:	164413   Click image for larger version
Old 03-06-2018, 11:30 AM   #14
I'd love to put the hardwired in - but with my luck my 'rewiring the coach' will somehow bite me in the backside when it comes warranty or ESP time.
2020 Rockwood Mini Lite 2509s
2019 F-150 3.5 EB SCREW Max Tow - 1797 payload
Blue Ox SwayPro w/ 1000 lb bars
s1njin is offline   Reply With Quote
Old 03-06-2018, 11:31 AM   #15
cavie's Avatar
Next use #10 sjo cord. stranded wire.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-06-2018, 11:36 AM   #16
Chief T's Avatar
I love sideways pictures in the morning... it helps me stretch and crack my neck. Cheers.
2017 Tracer Air 206
2012 GMC Sierra 1500 SLT 6.2l
Days camped 2017: 7
Days camped 2018: 15
Days camped 2019: 15
Chief T is online now   Reply With Quote
Old 03-06-2018, 04:05 PM   #17
I know right?! When I uploaded them they were straight. Guess the website thought you might need to work out some kinks.
Old 03-15-2018, 01:28 PM   #18
this is a great thread for a guy new to this...
Thanks!
R
RSW3 is offline   Reply With Quote
Old 03-15-2018, 02:05 PM   #19
I like most that you printed the error codes and have it right there. I have to google for the dang instructions every time!
Old 03-15-2018, 02:27 PM   #20
cavie's Avatar
My money's on you using an I-phone. They don't play nice with this forum.
