Old 11-09-2016, 05:58 PM   #1
Rodgers's Avatar
Question The Geo Method
We are heading out this week and want to use the GEO method on the first leg of the trip to start things out clean. Once we reach our first stop can we then put the normal RV Trine in without dumping and fill the black tank until it needs to be emptied or will the RV Trine and GEO chemically react so that nothing works as it should?
Tony & Cheri
Rodgers is offline   Reply With Quote
Old 11-09-2016, 08:37 PM   #2
asquared's Avatar
The only thing I would look out for is if the rv trine has formaldehyde and you use any bleach, otherwise you should be fine. Bleach and formaldehyde mixed can create a very bad mixture (think chlorine gas). We use liquid tide and liquid calgon water softener. Make sure you get water softener not fabric softener. We use the geo method exclusively.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-10-2016, 10:27 AM   #3
BGinVA's Avatar
Send a message via AIM to BGinVA
I use a cup of Cascade dishwasher liquid with a couple gallons of water.
BGinVA is offline   Reply With Quote
Old 11-10-2016, 10:27 AM   #4
Restcure's Avatar
We do too and have for years with very good results.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 11-10-2016, 10:53 AM   #5
Islander's Avatar
__________________________________________________ __________
X3 Used the Geo Method for years as well.
(powder laundry soap & powder calgon water softener)
No odours, no plugs, level gauges keep working and saved money.
IMO... those expensive chemicals that brag to 'break down' the waste may do so after they reach the septic system ..but I find it hard to believe they will do any good for the few days they are in the holding tank of the RV.
I may be wrong... but, I just cant buy into the hype.
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 11-10-2016, 11:38 AM   #6
Canadian Member
We also use the GEO Method exclusively. The black tank sensors work fine but the grey tank sensors are showing partially full when the tank is empty. We're trying degreasers to see if that helps. We have a good idea when the grey tank will be full so its not a big deal for us. It's only backed up into the shower pan (the lowest point) once so we know what the limit is.
In the Spring I'll be doing a treatment with RV Digest-It which should fix the sensor problem.
Old 11-10-2016, 12:30 PM   #7
Who Dares, Wins
doc73's Avatar
I used to use the Geo method, also used without.. Same results. I use a flush king and flush twice after dumping and all works well.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 11-10-2016, 12:58 PM   #8
I've been exclusively using RV Digest-It and find it to work very well. Before a trip, I add about 4 gal of water and a couple of "glugs" to a pail and pour this down the toilet. Subsequent dumps show clear water flowing freely using the black tank rinse.
BTW, I've also used their Septic System Rejuvenator and Septic System Digester products with expected results at home.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 11-10-2016, 01:39 PM   #9
Dave Lyon's Avatar
I use GEO Method as well. I put a mixture of laundry soap and Calgon in the black tanks with a scoop of "Odorlos" granular. there is no reaction and it works great.
I use Waldex Elemonate in the gray tank with success.
Elemonate Grey Water Deodorizer and Tank Cleaner - Walex TOI-61776 - Sewer Deodorizers & Treatment - Camping World
When you're done your trip fill the tnaks with water and rinse, repeat....repeat.
My sensors are still working.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 01-16-2017, 05:19 PM   #10
lastayt's Avatar
We used to have a full sized RV but we have down sized and now have a FR Rockwood HW. I want to use the home made black water treatment but can not find the amount I should use in a 5 gallon tank. I'm not worried about clogs or buildup, 5 gallons gets dumped very frequently, just odor control. Any one have an idea about the amount I would use?
We also use a 5 gal tank for our grey water. Other than commercial treatments what is a good grey water alternative?
lastayt
Rockwood A213HW
2016 Dodge Ram 1500
lastayt is offline   Reply With Quote
Old 01-16-2017, 07:28 PM   #11
Canadian Member
lastayt
Rockwood A213HW
2016 Dodge Ram 1500
The Geo Method serves to both prevent clogging and prevent odors. We don't use anything else.
Here's a link to the recipe:
https://sites.google.com/site/cbruni/
You could probably reduce the quantities proportionately for your 5 gallon tank. It works on both black and grey tanks although you may want to occasionally use a degreaser in the grey tank if you do dishes in the sink.
