Old 02-15-2014, 02:19 PM   #31
TF-Kevin's Avatar
I call the Cresent wrench a knuckle buster
Kevin & Debbie and our little dog Emma
2004 F-150 Lariat 4X4 Ext Cab 5.4
2010 Flagstaff Shamrock Hybrid 19
TF-Kevin is offline   Reply With Quote
Old 02-15-2014, 02:21 PM   #32
Ford Idaho's Avatar
Originally Posted by Weezer View Post
Lowe's has a clearance right now on a duo deal; 18v Drill plus an impact drill...two batteries. Impact drill would be nice for lug nuts, plus it's a 1600 in/pound torque wrench.
I bought this for the lug nuts.
Shop Kobalt 8-Amp 1/2-in Corded Impact Wrench at Lowes.com=
I am terribly hard on tools that need batteries so I am better off with corded power tools.
Old 02-15-2014, 02:23 PM   #33
B47
Yep it's been called that and many other things regardless of whether you spell it correctly or not.
Old 02-15-2014, 03:06 PM   #34
Brother Les's Avatar
1) two rolls of Duck Tape
2) Sledge Hammer
3) My attorneys phone number.
Brother Les
Old 02-15-2014, 03:12 PM   #35
dcheatwood's Avatar
Originally Posted by Larry Tiner View Post
Having fought ants numerous times --- and careful to not use pesticides --- I carry corn meal. When sprinkled around, ants can be controlled in a harmless manner.
Does anyone have other ideas?
Lighter fluid and a match if I'm home.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 02-15-2014, 03:16 PM   #36
Ford Idaho's Avatar
2) Sledge Hammer
You forgot about the wood block for the sledge.
Old 02-15-2014, 04:00 PM   #37
[QUOTE]Never did hear of a cheater bar being called a "Johnson Bar" however. /QUOTE]
Might be based on an old steam railroad term. The bar that is moved to change the period of time the steam valves to the locomotives cylinders are open, and to change which cylinders (left or right) get steam first (allowing the locomotive to run in reverse) is often called a Johnson Bar. I think we've got a locomotive engineer (Choo Choo Man?) on here. Maybe he can relate.
2011 Traverse LT, 3.6L, FWD
Old 02-15-2014, 04:01 PM   #38
the block of wood would get in the way of what I was destroying.... er... fixing.
Brother Les
Old 02-15-2014, 04:08 PM   #39
Ford Idaho's Avatar
I see!
Old 02-15-2014, 05:02 PM   #40
kerrlakelover's Avatar
Agree on the fire extinquisher....stored in an outside compartment or the tow vehicle in case you can't get to the extinquisher inside.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
