Old 07-08-2011, 08:42 PM   #1
Touch Audio System
Any tip on the NOAA radio issue, where if they sent a alert, it turns on the unit. This can kill the battery, plus if on the external speakers, a bit annoying for others when you are away and your camper becomes the campground weather station,like it or not.
I simply turn off all speakers. When I remember...
I just found a manual PDF file, it did not come with a manual or a remote.
asanford is offline   Reply With Quote
Old 07-14-2011, 12:03 PM   #2
ken0042's Avatar
We had another thread where we were discussing this:
Cherokee 28BH Audio System Question
I had a solution that I reposted on post #28; however you will need the remote to be able to get it to work. I did price out a replacement remote at one point from LCI; and it was around $50.
Link
Wolf Pup T16P owner
"The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine." - Abraham Lincoln
ken0042 is offline   Reply With Quote
Old 07-16-2011, 09:49 PM   #3
I got the remote from the dealer, and I can turn the alarm off and on, but it doesn't effect the NOAA status in the upper corner of the display when the unit is off. I have not found a way to turn off the NOAA icon or alert feature. Very annoying situation. I may need to install and toggle, power switch....
