08-22-2017, 03:57 PM
Tow dolly
We have a 2015 Honda. Accord we're trying to haul but the straps keep coming loose. Any suggestions ?
08-22-2017, 04:38 PM
How new are the straps. After a couple years of use they tend not to hold as well. Only other would,be how you are tying down allowing movement to create slack.
08-22-2017, 06:28 PM
They are new can't seem to wratchit down tight enough
08-22-2017, 06:33 PM
Do they go over the tires? A picture would help. Possibly not starting correctly.
08-22-2017, 06:36 PM
How do I put pictures on site
08-22-2017, 06:39 PM
Got me on that one. I use tapatalk and that's not too hard. The ratchets depend on how you run the strap through, you need a couple wraps on the ratchet first.
08-22-2017, 06:40 PM
This is how we were told by the tow dolly rep to apply them
You have a strap that's connected at one end of the dolly or does it have a hook?
08-22-2017, 06:41 PM
A hook
08-22-2017, 06:42 PM
At the front of the tire, what does that ratchet look like!
08-22-2017, 06:44 PM
I don't have a picture of the ratchet but will try to get one and put it on here in a couple days. Thanks for taking time to try to help us
08-22-2017, 06:47 PM
It is slightly visible in the second picture
08-22-2017, 06:48 PM
Not a problem. I would like to see the split strap on top a little wider apart. At the bottom At least one or two wraps and then tighten it down.
08-22-2017, 06:51 PM
Do you mean the two separate straps or the smaller one that is in the middle from strap to strap
08-22-2017, 06:53 PM
Have you used this type before
08-22-2017, 06:54 PM
The one in the middle from strap to strap, I would make a little longer if you can.
08-22-2017, 06:55 PM
We use a similar set,up on the race car in the trailer.
It doesn't appear to be adjustable
08-22-2017, 06:56 PM
Presewn
