Old 10-22-2014, 10:06 AM   #11
I'm not the weight police, by any means. But you most likely have a payload in the 1500lbs range. My research has led me to believe that adding air bags and XL or load range E tires and better shocks give you a more capable truck than the MaxTow package, which offers an additional 500 pounds of payload. I'm not gonna argue about stickers. It appears that if you load nothing into the truck and have no passengers, you can probably come close to not breaking a GVW of 7700(the max tow GVWR). If you carry several passengers and load heavy for long trips, you'll easily go over that by another 1000 pounds or more. That's substantially over, and even I would argue that you are in 3/4 ton territory- and I advocate heavily for the F150 EB being more capable than it's payload number suggests. With that being said, the only way I personally would be comfortable with towing what you are asking is with the following caveats: 1. Make the upgrades to the truck (Airbags, Rancho RS9000XL shocks or similar, load range E tires or XL load rating if 20"). 2. I only camp close to home and pack light. Take a 2nd vehicle to carry passengers and additional supplies if necessary. And 3. Slow down, take your time, and be cautious.
I'm assuming you have a SCrew with 3.55 gears and XLT trim. If not, the above advice could change substantially.
Old 10-22-2014, 10:07 AM   #12
another_newfie's Avatar
Until you post the specifics of your truck everything is speculation. It is unlikely you'll be able to though based on your description. Unless you have the HD Payload package and haven't mentioned. Post more information about your truck and at least everyone can make an informed conclusion. Mind you the weight police are already hiding in the bushes with their scaled pointed directly at you, so be ready....
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 10-22-2014, 10:13 AM   #13
Originally Posted by LandJ View Post
I might be a little off topic, but have been thinking about 5th wheel and trucks lately. I would prefer a 1/2 ton truck for cost and ride while not towing. Some trailers claim to be 1/2 ton towable, but most trucks fall short in the payload department even for those "light" rigs.
Question: what happens if you have an accident, your fault or someone else's, and it's determined you were over weight? Do you lose your house??? I'm sure accidents have happened, but I'm not aware of real world situations.
BTW, I'm not trying to start anything, just curios about what would happen.
I suggest you search the forums as this has been hashed out thoroughly. Maybe some members can point you to some threads on this issue.
Old 10-22-2014, 10:18 AM   #14
LandJ's Avatar
Yeah, I gathered. I see it's a harshly contested topic. Personally, I worry more about the "feel" than a number. I also know, however, that a number can be used to hang you if they want to.
Thanks for the advice, I'll do more searching....
John and Linda
2016 Rockwood 2604WS
2017 Ram 3500 CTD SRW
2016 - 47 nights
2017 - 47 nights
LandJ is offline   Reply With Quote
Old 10-22-2014, 10:27 AM   #15
Originally Posted by palominoryda View Post
Ain't gonna happen. Couldn't handle weight, not enough strength in the horse power to pull it‼
"not enough strength in the horsepower to pull it"???? Power would be the least of my concerns with the Ecoboost. Considerably more power than the turbocharged diesels of the late 90's and no one ever doubted their ability.
Old 10-22-2014, 10:32 AM   #16
Just a quick thought- why not look at travel trailers with that floorplan? There are several out there that have the same or similar floorplan. Very likely you can get the tongue weight in the 900-1000lb range when fully loaded. Get a ProPride hitch and it will pull very similar to a fiver with no worries of sway. If you are dead set on a fiver because you've had bad sway experiences or heard of them, you really need to give the ProPride a try.
Old 10-22-2014, 06:31 PM   #17
I am not understanding how you are saying that adding the listed items will make a standard truck more capable than a max tow equipped truck? Yes, those items will help, but they won't make it more capable TV than a max tow equipped truck.
In order to have max tow, his truck would be required to have 3.73 gears. Max tow adds a heavier front suspension and in some cases (not all) adds a heavier rear suspension. The 7650/7700 cannot be had without 3.73 and max tow. If he has 3.55 he would have the GVWR would likely be in the lesser 7200 range.
OP: You didn't state whether or not you have max tow or the 535 towing package. Good info to know would be rear end gears, GVWR, FGAWR, RGAWR, particular tow package, current tires, any suspension mods (current or planned), etc. . . As others have stated, without this type of information, it would be difficult to truly answer your question correctly.
madmaxmutt is offline   Reply With Quote
Old 10-22-2014, 06:52 PM   #18
ARLO
The ecoboost gets it's power from te twin turbos. I am not saying tha tit can't tow the 8528 but it would really test the turbos and turbos do not like to get overused. I would opt for a 3/4 to 1 ton bigger V8. If you are down around 7500 to 8500, yes ecoboost.
rlocicero is offline   Reply With Quote
Old 10-22-2014, 07:09 PM   #19
Well, the ecoboost in the F150 is in boost almost all the time and I haven't heard of any systemic problems with the turbos on them. The parts of an F150 that would 'get overused' are not the turbos. The suspension and brakes would come into question well before the motor.
Old 10-22-2014, 07:31 PM   #20
B and B's Avatar
I am camping right now in Frankenmuth MI. Travelled from Kitchener , Ontario. Across i69 washboard. No issues at all. I have 8000 km towing this year on the truck, no issues.
My measured weights today are.
Front Axle 3,500 lbs
Rear Axle 5,070 lbs
Trailer 7,716 lbs
I have a heavier 8289 Rockwood. I am lighter today, dropped the bikes off the roof makes the front weight a little more when loaded. As well normal i have a full tank of water which would make the rear axle lighter but add 700 lbs to trailer weight.
Today I am under he max towing weight by 100 lbs, the combined weight is 16,200 and I am under that by 900 lbs.
Do as you please and what you are safe doing. BTW the new 2015 F 150 blows mine out of water for towing capacity when properly equipped.
I do not tow over 62 mph or 100 kph and do have upgraded LT Tires on the truck and GY Marathons D on the trailer.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
towing, truck
