07-25-2016, 10:17 AM
Towing with a Blue Ox tow bar
Thinking of buying a Blue ox tow bar to hook up a 2010 suzuki sx4
its low to the ground and I will be hooking it up to my 2014 Forest river Class C motorhome 3051S 32 ft long
should the bar be level when connected ? and towing a vehicle
Rob & Elizabeth Sweeney
Having fun in our Forester Gump (2015 3051S forester)
07-25-2016, 12:45 PM
I think they suggest 2" up or down from level.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
07-26-2016, 12:15 PM
I just watched a Blue Ox video about towing and it was stated that for "optimum 100% effectiveness" the vehicle towed should be level. Of course, for an additional purchase you can buy a "leveler adapter" in a wide variety of up and down inches.
07-26-2016, 06:49 PM
Level is best. Blue ox is crap!
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
07-27-2016, 01:19 PM
This is how we traveled to Whitehorse and on to Alaska. Keep the two vehicles as level as possible ( + / - 2 " works fine with no apparent stress on the toad ).
07-27-2016, 08:25 PM
I used a blue ox for 3 years with an 8" drop bar. Wasn't perfectly level but within 2 inches. Worked great. Kept it thinking we might go back to a large MH instead of the 5er. Never any problems with it.
2014 Signature Ultralite 8280ws
2013 Chevy 2500 Duramax
07-27-2016, 09:47 PM
We tow a Jeep Wrangler behind a Sunseeker 3010DS using Blue Ox equipment and could not be happier. Our installer recommended a Brake Buddy instead of the Blue Ox Patriot and that has worked out well as well. The Jeep lines up well with our Sunseeker. Have never met a person using Blue Ox that had any problems at all!
07-27-2016, 10:36 PM
Blue Ox
Sorry to disagree, pal....the Blue Ox system is robust and absolutely reliable. Easy to set up and use, as well.
07-27-2016, 10:48 PM
I agree with larryo. purchase a Roadmaster All-Terrain non-binding aluminum tow bar.
07-28-2016, 08:04 AM
When we had our Pioneer Blue Ox was what we used. Hubby was really happy with the bars.
07-29-2016, 10:13 PM
I tow a lot and have gone through 7 in 5 years. They just wear out! They get very sloppy. Yes they are nice for hooking up but for me they don't last. They have a policy where they give you $150 off a new one when your old one wears out so they know there are isdues. I finally went to a machine shop and got one custom made.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
07-30-2016, 07:13 AM
I would recommend the bar tilt up a little. the MH end slightly higher than the Toad end.
This way when you stop, it forces the front of the toad down, which will improve the effectiveness of the toad brakes.
If you have the Toad end higher, the toad tends catapult itself upward and the toad brakes become less effective.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
07-30-2016, 07:35 AM
I couldn't DISAGREE more. Towed with 2 different Blue Ox bars and 3 different vehicle plates for 20 years behind 3 different DP'ers. NEVER had a single issue with the Blue OX equipment in all those years. Also used the Blue Ox Patriot brake system on our last Pusher with great results!
30 years RV'ing
11 different RV's
07-30-2016, 07:39 AM
Unbelievable!!!!!!!!!!! I towed over 100,000 miles during my 20 years and only changed to a new Blue Ox as I wanted the lighter aluminum unit.
30 years RV'ing
11 different RV's
07-31-2016, 09:19 PM
I've towed 5-6000 miles with my BlueOx tow bar and really like it.
It is supposed to close to level. Found this thread on the IRV forum that was helpful. http://www.irv2.com/forums/showthread.php?t=16631
Forester 2451s
Happy Campin!
Forester 2451s
08-02-2016, 09:44 AM
I have towed a jeep with the blue ox bar for 8 years now. Never a single issue. Great product! We have always towed level or slightly high, within an inch or two.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
08-03-2016, 04:52 AM
I tow over 100,000 miles a year. Have been for the past 11 years. I have gone through 7 of them. My custom made one is as good as the day I bought it. I also use a brake buddy. Dan's hitch world in Elkhart will steer you away from Blu Ox and Dually Depot in Elkhart doesn't even handle them anymore, but they will special order if you like. But if they work for you that's great. I push them to the limit as I pull a 1 ton dually. Truck weights 8500 and Ox is rated for 10,000. They don't Last under extreme usage but I suppose they are OK for the average user.
10-10-2016, 10:13 AM
Just sighed relief reading this thread. We bought the new Wrangler Sport because it is a high riding vehicle, and light enough to tow behind our 22' MH. This afternoon I'm taking the Wrangler to our local RV mechanic to install the Blue Ox hitch, then tomorrow bring the MH up there for it's part of the install. Yes, I am nervous!
Toni and Sal
2016 Forester 2291S
