Old 10-18-2016, 02:21 PM   #11
Originally Posted by Larry Cole View Post
Great idea! It won't work for my Wildcat because I don't have access to the cross members of the frame. My entire undercarriage is covered in. I suppose I could weld a permanent bracket to the frame and use that but not sure I want to go to the expense or the trouble.
Love the idea though!!
Same here... the coroplast sheeting is attached to some sort of bracket that hangs down below the frame, so no direct access to the frame itself.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 10-18-2016, 03:44 PM   #12
Any more pics please?
Thanks.
Lukegsdaddy is offline   Reply With Quote
Old 10-18-2016, 03:56 PM   #13
Originally Posted by Bobaloo View Post
Great idea! Thanks for sharing
x2
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 10-18-2016, 04:18 PM   #14
Blog: RVroadtripper.com
hbillsmith's Avatar
Interesting. I was thinkin....
The Mor-Ryde Suspension (and others) has a cross bar that goes across from one frame rail to the opposite frame rail (just behind the axles). What if you put one of these cargo bars from say the base/foot of the right-rear scissor jack up to the corner where that cross bar intersects the frame on the left. And then add a second cargo bar from the foot of the left scissor jack up across to where the right scissor jack attaches to the frame.
Basically, its one cargo bar between the 2 scissor jacks at rear AND one cargo bar at an angle from a rear scissor jack up to the frame cross bar.
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 10-18-2016, 05:48 PM   #15
I'm sure there are a few ways to do it that would work fine. I'll post a few better pics shortly
Tzrider is offline   Reply With Quote
Old 10-18-2016, 07:11 PM   #16
Best tip I've seen in a long time.
04 Ram 3500
07 Ram 3500 X2
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 10-18-2016, 07:29 PM   #17
Brwk's Avatar
Don't the braces that go in between the wheels stop the movement?
Brwk is offline   Reply With Quote
Old 10-18-2016, 09:31 PM   #18
They do, but rubber is soft and will move regardless how tight the chocks are. Also, rubber changes with temperature so that is also a factor .
Larry Cole is offline   Reply With Quote
Old 10-18-2016, 09:48 PM   #19
D_B Travelers's Avatar
I am headed to Harbor Freight tomorrow to pick up a couple of these and try this out. Great Tip! I already have one in the bed of the pickup so I may only have to get 3 more.
D_B Travelers - 8 nights in 2017, 35 nights in 2016. 1st RV 2014 TT WJ3001w, new 2016 FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 1996)
D_B Travelers is offline   Reply With Quote
Old 10-18-2016, 10:45 PM   #20
Here are a couple more pictures showing a little better detail of how I place them. I hope those of you that try it have as good of results as I did and that you find it a useful tip
trailer
