10-17-2016, 08:21 PM
Trick for stabilizing trailer when parked
This past weekend while camping at biketoberfest my wife was saying how much she wished we could keep our toy hauler from moving when we are walking around. I knew about the JT arms and that gave me an idea. I had an adjustable cargo bar in the back of my truck so I grabbed it, put it between the jack and frame, tightened it and wow what a difference in minimizing movement. It worked so well I drove over to Lowes and bought three more for 20.00 each and put them in place on all four jacks and now our RV is damn near solid and as an added benefit I use them to stabilize cargo in our storage compartments when traveling
10-17-2016, 09:36 PM
Great idea and solution!
2015 Rockwood 8329SS TT
2004 Chevy 2500HD D/A 4X4 CC SB
Andersen Weight Distribution hitch
10-17-2016, 10:15 PM
I go RV'ing not Camping
How did you attach it to the frame?
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
10-18-2016, 06:31 AM
Jgourlie
I didn't attach it I put one end against the jack and the other against a frame rail cross beam
10-18-2016, 08:53 AM
Interesting idea and less expensive then what I did, I went the steady fast route to achieve a stable platform.
Retired Navy
2016 Flagstaff 26 FKWS
10-18-2016, 09:50 AM
Seadog
Well they do say necessity is the mother of invention or at least some redneck engineering. On a positive note they worked well and have other uses
10-18-2016, 10:11 AM
very clever, I love ingenuity
10-18-2016, 10:26 AM
Great tip!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
10-18-2016, 12:52 PM
Great idea! Thanks for sharing
2013 Rockwood 2504
2015 Silverado 1500 4x4 Z71 Double Cab
Diablo and Lew Custom tuned
Tony & Catnis, campin' kitties
10-18-2016, 01:42 PM
Great idea! It won't work for my Wildcat because I don't have access to the cross members of the frame. My entire undercarriage is covered in. I suppose I could weld a permanent bracket to the frame and use that but not sure I want to go to the expense or the trouble.
Love the idea though!!
10-18-2016, 02:21 PM
Same here... the coroplast sheeting is attached to some sort of bracket that hangs down below the frame, so no direct access to the frame itself.
10-18-2016, 03:44 PM
Any more pics please?
Thanks.
10-18-2016, 03:56 PM
x2
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
10-18-2016, 04:18 PM
Blog: RVroadtripper.com
Interesting. I was thinkin....
The Mor-Ryde Suspension (and others) has a cross bar that goes across from one frame rail to the opposite frame rail (just behind the axles). What if you put one of these cargo bars from say the base/foot of the right-rear scissor jack up to the corner where that cross bar intersects the frame on the left. And then add a second cargo bar from the foot of the left scissor jack up across to where the right scissor jack attaches to the frame.
Basically, its one cargo bar between the 2 scissor jacks at rear AND one cargo bar at an angle from a rear scissor jack up to the frame cross bar.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
10-18-2016, 05:48 PM
I'm sure there are a few ways to do it that would work fine. I'll post a few better pics shortly
10-18-2016, 07:11 PM
Best tip I've seen in a long time.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
10-18-2016, 07:29 PM
Don't the braces that go in between the wheels stop the movement?
10-18-2016, 09:31 PM
They do, but rubber is soft and will move regardless how tight the chocks are. Also, rubber changes with temperature so that is also a factor .
10-18-2016, 09:48 PM
I am headed to Harbor Freight tomorrow to pick up a couple of these and try this out. Great Tip! I already have one in the bed of the pickup so I may only have to get 3 more.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
10-18-2016, 10:45 PM
Here are a couple more pictures showing a little better detail of how I place them. I hope those of you that try it have as good of results as I did and that you find it a useful tip
