Old 09-25-2017, 11:45 PM   #1
Global Nomad
Scheinin's Avatar
TST 507 Booster
I originally posted this on the only thread I could find on the subject, which was over a year old. The note to that threat seem to suggest I start a new thread, so I am.
I just purchased the TST 507 system and mounted the booster in the battery compartment of my 5th wheel. My question is: is there any detriment to leaving the power to the booster on all the time (rather than disconnect each time I set up camp)? I move about every 3-7 days. The booster is directly wired to my 12 volt battery.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is online now   Reply With Quote
Old 09-26-2017, 07:19 AM   #2
SeaDog's Avatar
Other then pulling a little power from your batteries there is to real down side to leaving it connected. No different then other hard wired items.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-26-2017, 07:32 AM   #3
Global Nomad
Scheinin's Avatar
Thank you.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 09-26-2017, 07:42 AM   #4
I know this doesn't answer your question but have you tried the TST without using the booster? I originally purchased a booster with mine as well and determined that it wasn't needed. Mine works fine all the time without the booster. A pleasant surprise...Also pleasantly surprised at battery life. I've had the original batteries in the sensors for 15 months with no issues. I only charge the monitor screen about 2x annually (helps to power it off at landing).
Charleston, SC
2016 Silverado 1500 LTZ
2016 Wildwood 27RKSS
seakayaker is offline   Reply With Quote
Old 09-26-2017, 08:01 AM   #5
Georgia Rally Coordinator
aceinspp's Avatar
When I installed mine I just installed an on off switch on my battery box and is protected by the over hang on the cover to battery. Works great. Why leave power on if on don't have too. New color monitor works great also. Lot faster. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped 2017 62
Days camped 2018 67
Days camped 2019 54
aceinspp is online now   Reply With Quote
Old 09-26-2017, 08:09 AM   #6
W5CI's Avatar
I just received my TST Repeater yesterday, My system constantly looses the signal from one wheel the all of the rest. I can stop and it will reconnect. Hopefully the repeater will help. I am putting it in the battery compartment as well
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 09-26-2017, 08:18 AM   #7
twohand's Avatar
X2
FROG IL-0076-090
2016 Wildcat 323RBX, 1992 Excel Legacy "guest house"
98 Honda Shadow ACE, 78 Honda CB400A Hondamatic
Nights camped: Ď16 - 24, Ď17 -33, Ď18 - 27, Ď19 - 20
twohand is offline   Reply With Quote
Old 09-26-2017, 09:28 AM   #8
This is what I did.
A small toggle switch inline and I can turn it off when parked.
I had the same problem.
I read where many users with longer rigs had no dropouts but at 35', I had the same issues described above.
The repeater solved my problem too.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 09-26-2017, 10:45 AM   #9
Global Nomad
Scheinin's Avatar
Yes, I did try it for a month without the booster. I would go about an hour and half, then I would loose a reading on one or two tires. I turn the unit off and on again, and an hour an half, same thing. I called technoRV where I bought the unit, and they put me in touch with a tech from TST who told me I needed to install the booster (which i bought when I bought the unit). He is the one to suggest mounting it in the battery compartment of my 5th wheel, hooking directly to battery. On most recent trip of 4 hours, no problems.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 09-26-2017, 08:36 PM   #10
Truck System Technologies Rep
Hello,
Many people mount the booster to the battery, the draw is very low. You should have no problems at all. If you have any questions feel free to contact meat 210-420-0132
Thanks,
Mike Benson
TST TPMS
mbenson1234 is offline   Reply With Quote
Old 09-26-2017, 10:07 PM   #11
Global Nomad
Scheinin's Avatar
Originally Posted by mbenson1234 View Post
Hello,
Thanks,
Mike Benson
TST TPMS
Thank you, very much.
Steven J. Scheinin
2015 RAM 3500 4X4
Old 01-09-2018, 09:04 PM   #12
HeavyPuller's Avatar
TPMS 507 Best Ever
I mounted my repeater in the battery box on my tt as well. The repeater draws next to nothing from battery so when I'm camping I just leave it on unless I'm stationary for long periods. But we like to Gypsy camp (moving from place to place every one to two weeks. Thinking maybe I might add a toggle switch someday so I don't have to remove the battery case top when I do want to turn the repeater off.
HeavyPuller
HeavyPuller is offline   Reply With Quote
