Old 06-17-2017, 10:05 AM   #1
TST 507 Receiver Mount for F250
I made a mount for my TST 507 receiver that should work for 2008-2016 F250's with the little coin storage thing in the dash. It attaches to the removable bracket on the rear of the receiver and wedges into the coin slot in the dash. Here are some photos if my description is clear as mud.
Name:	01a6a5c0ec16f3d1369b11dafb8111246e24d2002d (Small).jpg
ID:	141718   Click image for larger version
Name:	0160d65c88e51da95ba5e3c7f8142c09acd3c7243b (Small).jpg
ID:	141719   Click image for larger version
Name:	0136a7ab032ca9437ba4f9e95628262dad96e0ce7d (Small).jpg
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 06-17-2017, 11:40 AM   #2
Moparman1230's Avatar
Nice! Sure beats sticking it to the windshield!
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
Moparman1230 is offline   Reply With Quote
Old 06-17-2017, 12:14 PM   #3
Nice idea but you have to take your eyes from on the road to look at it. I just use a piece of Velcro and use the tray mount on the dash..
Old 06-17-2017, 02:29 PM   #4
I look when I first turn it on. No need to keep looking, that's what the audible alarms are for.
Lee and Anne
Old 06-17-2017, 02:44 PM   #5
Ok, might as well put it in your pocket then.
I sure like to monitor mine to see if pressure is changing. If I see a tire starting to drop I would immediately get off the road to check. Would not want to wait until alarm went off. Each to his own..
Old 06-18-2017, 01:34 PM   #6
Inuse a nato smart mount can switch between iphone gps and camera
Jerheye is offline   Reply With Quote
Old 06-18-2017, 02:22 PM   #7
I have used a "sand bag" type mount on the dash which can easily be turned to the driver or the passenger. Have had it for 6 years, and it works great.
JimMorrell is offline   Reply With Quote
Old 06-19-2017, 05:14 AM   #8
DouglasReid's Avatar
I have mine mounted in the same location but using a bit of that ultra sticky double sided gel; Works well and can be removed if I want. I even mounted the indicator light for my aux tank pump system right under it so I only have to look in one spot to tell me what I need to know while driving and transferring fuel.
The mount is at the very top of the picture:
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-19-2017, 09:14 AM   #9
I like the idea but my Ford has some switches and stuff in that location.
2019 Ram 3500 DRW HO Cummins, Aisin Trans and 4.10 gears.
2017 Flagstaff 8529 IKBS Classic Platinum Edition
Beauty and Beast is offline   Reply With Quote
Old 06-20-2017, 07:56 PM   #10
I mount it on the windshield on the passenger side and appoint my wife "Guardian of the Tires."
OldBob
I may be old but I'm trying, very trying.
2015 RAM 1500 - EcoDiesel
Rockwood Ultra V 2715VS
OldBob is offline   Reply With Quote
Old 08-05-2017, 10:21 AM   #11
Where did you get the black plastic piece that mounts to the rear of the receiver?
kkesler is offline   Reply With Quote
Old 08-05-2017, 09:05 PM   #12
The only problem I see with that mount is that the antenna is very low and the signal has to travel through the metal body. As long as it works for you that's great. My problem has been that I have to mount it in a place where the signal is nearly line of sight to the tires. When I mounted it lower my receiver would sometimes lose the signal and we would get the loud alarm.
OldBob
Old 08-06-2017, 05:43 AM   #13
Even with mine mounted on top of the dash to the left of the steering wheel I kept having sensors drop off.
I had to get a repeater to solve the problem.
Old 08-07-2017, 10:47 AM   #14
Truck System Technologies Rep
TST TPMS
Good Thread. Thanks for sharing! If anyone has any questions feel to reach out or call me at 210-420-0132
Thanks,
Mike Benson
TST Sales Manager
210-420-0132
mbenson1234 is offline   Reply With Quote
Old 08-07-2017, 11:12 AM   #15
Thanks,
Mike Benson
TST Sales Manager
210-420-0132
I can tell you that these guys are as "GOOD as Gold". They solved the one issue I had quickly and perfectly..............Better than I had hoped, actually!
Many Thanks, Mike!
Old 09-29-2017, 02:55 PM   #16
It came with the unit.
Lee and Anne
Old 09-29-2017, 02:56 PM   #17
Almost 3k miles towing with it mounted like this and no signal drops.
Lee and Anne
Old 10-03-2017, 06:13 AM   #18
TST Color Monitor
Thanks for sharing!!!
Check out our new Color Monitor works with all 507 Systems.
Thanks,
Mike Benson
TST TPMS
210-420-0132
Name:	New Color Monitor.jpg
Old 10-03-2017, 06:33 AM   #19
Thanks,
Mike Benson
TST TPMS
210-420-0132
That looks GREAT Mike, if my monitor ever quits I will replace it with the color unit.
Old 10-05-2017, 02:51 PM   #20
Too old to be too smart
SpringerPop's Avatar
I bought the color monitor for the truck, and will use my old monochrome unit in my trailer as a constant pressure monitor in my electronics closet. If it goes off in the middle of the night, I will silence it with the knowledge that I will have something with which to deal in the morning.
Of course, should the color monitor ever require a trip back to TST for some kind of repair, I have a spare ready to go. However, given the reliability of my mono unit, which I have had for over four years, I doubt the color one will have problems. Maybe a firmware update? Who knows?
The new unit's cradle mount is just going to sit on top of my dash in the same place the old one did. The photo in Post #3 could be mine (it isn't), only with a fuzzy dash mat. It's my preferred location for keeping an early-warning eye on my pressures.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
f250, mount
