Old 03-14-2015, 04:46 PM   #1
TT leveling
Newbie here! Just upgraded to the Prime Time avenger 27bbs. We had a rock wood pop up before this. When leveling the trailer side to side do you want to use both axles or is one ok?
ready4thewknd is offline   Reply With Quote
Old 03-14-2015, 05:30 PM   #2
New Member
RiverBird's Avatar
Important! Both. By design, one axle will not support the weight. We level with boards, but other systems are available.
RiverBird is offline   Reply With Quote
Old 03-14-2015, 05:41 PM   #3
Chevy Two's Avatar
2x-RiverBird. Welcome from Ga.
Sent from outer space! 🇺🇸😄😄🇺🇸
Chevy Two is offline   Reply With Quote
Old 03-14-2015, 05:49 PM   #4
ColoradoRick's Avatar
Yes, we've used lots of things to level...boards, those leggo-looking block things, and last year tried out these nifty things and they are my new favorite. (They are called Anderson 3604 Camper levelers.) The reason I like them is you can go up just a little or up about 4-inches, depending on how far you drive up on them.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 03-14-2015, 06:02 PM   #5
ColoradoRick do you know what the weight rating is on these levelers?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-14-2015, 08:36 PM   #6
We must be old fashioned compared to those red high tech looking levellers. We take two boards with us, they are 8 inches wide, two inches thick and 37 or so inches long and the second is cut 6-8 inches shorter with a wedge cut on the end to drive up on. The length and width will support both tires on both axles. If the campsite is out by more than the 4 inches than we have a problem to start with. I like it this way as if there is a pothole or root or something then I have the l x w x h to negiotate the obstacle. Not every CG looks or is level like a paved parking lot.
Kevin
tenttotrailer is offline   Reply With Quote
Old 03-14-2015, 09:11 PM   #7
camper1999's Avatar
I have these and love them. There is nothing easier unless you have and auto leveling system
2011 GMC 2500HD Diesel
Old 03-14-2015, 09:15 PM   #8
BGKirkham's Avatar
I have the Anderson levelers and they really work well.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
BGKirkham is offline   Reply With Quote
Old 03-14-2015, 09:33 PM   #9
I've been researching the Andersen levels I have the camco tri level that I used for the pop up was going to purchase one of the Andersen to use for the second axle
Old 03-14-2015, 09:34 PM   #10
By the way thanks for all the responses and the review on the Andersen levels
Old 03-14-2015, 09:38 PM   #11
It says on the box for trailers that weigh up to 30,000 pounds.
Rick & Karen
Monument, Colorado
Old 03-14-2015, 10:00 PM   #12
geotex1's Avatar
I carried assorted leveling wood for decades... Now I have Andersons! DW loves perfectly level with them over close enough. In case we get a muddy/soft site, I do still have two pieces of marine plywood that can go down for them to bear upon.
geotex1 is offline   Reply With Quote
Old 03-14-2015, 10:19 PM   #13
2015 Cherokee 274DBH
acspencer's Avatar
We also have the Anderson levels. They work great, so easy and quick!
acspencer is offline   Reply With Quote
leveling
