03-14-2015, 04:46 PM
TT leveling
Newbie here! Just upgraded to the Prime Time avenger 27bbs. We had a rock wood pop up before this. When leveling the trailer side to side do you want to use both axles or is one ok?
03-14-2015, 05:30 PM
New Member
Important! Both. By design, one axle will not support the weight. We level with boards, but other systems are available.
03-14-2015, 05:41 PM
2x-RiverBird . Welcome from Ga.
Sent from outer space! 🇺🇸😄😄🇺🇸
03-14-2015, 05:49 PM
Yes, we've used lots of things to level...boards, those leggo-looking block things, and last year tried out these nifty things and they are my new favorite. (They are called Anderson 3604 Camper levelers.) The reason I like them is you can go up just a little or up about 4-inches, depending on how far you drive up on them.
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
03-14-2015, 06:02 PM
ColoradoRick do you know what the weight rating is on these levelers?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
03-14-2015, 08:36 PM
We must be old fashioned compared to those red high tech looking levellers. We take two boards with us, they are 8 inches wide, two inches thick and 37 or so inches long and the second is cut 6-8 inches shorter with a wedge cut on the end to drive up on. The length and width will support both tires on both axles. If the campsite is out by more than the 4 inches than we have a problem to start with. I like it this way as if there is a pothole or root or something then I have the l x w x h to negiotate the obstacle. Not every CG looks or is level like a paved parking lot.
Kevin
03-14-2015, 09:11 PM
I have these and love them. There is nothing easier unless you have and auto leveling system
2011 GMC 2500HD Diesel
03-14-2015, 09:15 PM
I have the Anderson levelers and they really work well.
Gary
2017 Cedar Creek Silverback 37MBH
2008 Dodge Ram 3500 6.7L, DRW, 4.10 Rear end
03-14-2015, 09:33 PM
I've been researching the Andersen levels I have the camco tri level that I used for the pop up was going to purchase one of the Andersen to use for the second axle
03-14-2015, 09:34 PM
By the way thanks for all the responses and the review on the Andersen levels
03-14-2015, 09:38 PM
It says on the box for trailers that weigh up to 30,000 pounds.
Rick & Karen
Monument, Colorado
03-14-2015, 10:00 PM
I carried assorted leveling wood for decades... Now I have Andersons! DW loves perfectly level with them over close enough. In case we get a muddy/soft site, I do still have two pieces of marine plywood that can go down for them to bear upon.
03-14-2015, 10:19 PM
2015 Cherokee 274DBH
We also have the Anderson levels. They work great, so easy and quick!
