Old 06-18-2016, 03:20 PM   #1
TT lift blocks
Needed to raise my TT 2", as spring width is 1.75" it was easier to get 1.75" square aluminum bar stock. Found a 16" long piece locally so no shipping. U bolts need to be longer, not a stock item for 3500# axle so found a company on line who makes custom size u bolts, $9.75 each plus shipping. I'll try to attach pic's of finished item. Requires cutting bar stock 3 times to get four 4" pieces. Prior to cutting, marl center of bar and center of each 4" piece. Drill 1/4 " pilot hole. My axle needed a 5/8 hole in top to fit the stud in spring ans a 3/8 X1" bolt threaded into bottom to plug into hole in spring perch. Came out pretty well. I did have to drill out the top plate to 1/2 " for the new u bolts.
Name:	block IMG_0719.JPG
ID:	111480   Click image for larger version
Name:	block 1 IMG_0721.JPG
ID:	111481   Click image for larger version
Name:	block 2 IMG_0722.JPG
ID:	111482   Click image for larger version
Name:	block 3 IMG_0717.JPG
ID:	111483   Click image for larger version
Name:	block 4 IMG_0720.JPG
Name:	block 5 IMG_0718.JPG
pdqparalegal1 is offline   Reply With Quote
Old 06-21-2016, 08:04 AM   #2
41ford's Avatar
Looks good, many of us street rodders use the same technique for raising or lowering our vehicles.
Why did you raise it and how does it handle?
JR
2016 Forest River Heritage Glen 276RLIS
2017 Chevrolet Silverado LTZ 2500HD Duramax
Pasco, Washington
41ford is offline   Reply With Quote
Old 06-21-2016, 08:21 AM   #3
Lift
I went to 15" tires that were taller, not by much, but did hit fabric under TT. It only raised it 1.75" which clears fabric. Had to readjust WDH to compensate. As usual, first adjustment was too high, second was right hieght but had to adjust head angel. Went back to Cat scales. Front fendr now up 1/4 " only 20# OFF front axle. Should work. With 6500# trailer, 1.75" doesn't seem to affect C/G.
Old 06-21-2016, 08:24 AM   #4
Restcure's Avatar
Nice mod!
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-21-2016, 08:40 AM   #5
SeaDog's Avatar
Did you switch to 15" to get a higher ply rating? The mod looks very professional and well done.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
lock
