Old 09-15-2015, 12:29 PM   #11
MilCop4523's Avatar
Originally Posted by Harkerr View Post
I find the biggest issue with a big rig is getting it stopped especially on a down grade. Practice and getting know your stopping distance
You are also taller. Know your height.
Our new to us 5th wheel is 11 foot 10 inches tall. on the spec sheet.
if a Transport truck is able to clear the zone then we are safe.
Good sam makes a GPS that permits you to input your trailer height and it will warn and reroute for low overheads.
5th wheel is the best way to tow.
DW originally wanted a tag along and the first time out she was fearful when a transport truck sucked the air off my trailer.
after that for 3 yrs i told her no complaining - this is what she wated.
we sold ours this July and bought a used 5th wheel bunk house
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 09-15-2015, 12:52 PM   #12
Iwannacamp's Avatar
It may sound stupid... Especially if we are scouting camping areas...I pretend the trailer is behind me as I am touring. I watch trees and curbs etc. I am not real experienced in towing...mostly just dream of camping. In my case I can kinda "feel" if the 5er will fit.
We went to Dangerfield state park...man the spots are short. We could have only parked in a few back in spots. I have never seen any more unlevel than these. At least a foot from side to side and some two feet or more front to back...it was crazy. You would have to tie your trailer to a tree literally. The pull throughs were very curved...but lots of trees. Pretty park just narrow spots and roads.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-15-2015, 01:13 PM   #13
As others said, which concur with my observations:
1) You will have to take turns much wider.
2) It's easy to forget how tall you are, likely around 13'. Beware of limbs.
3) Much easier to handle heavy side wind, or passing trucks. Much easier.
4) Heavier unit means more stopping distance, and more pull needed going uphill.
5) Be careful of the TV antenna. More difficult to see and more likely to snag if left up.
6) Depending on hitch, you may have "chucking" or "jerking" crossing bumps. If so, most can be removed by changes in the hitch and 5th wheel suspension. Just post for advice.
7) Downside is that big 5th wheels may not fit in many of the older national park sites whereas a smaller trailer or "C" will.
8) Biggest upside for us is even with the grandkids, when it's foul weather outside, we can all relax inside without being "confined".. Wife and I take the recliners.
9) Likely the biggest initial problem is the expectations of more problems because bigger is suppose to be more difficult. Not so.
10) Expect to lose about 2 mpg.
RubberNail is offline   Reply With Quote
Old 09-15-2015, 01:18 PM   #14
Height problems are usually branches in campsites.
Harkerr is offline   Reply With Quote
Old 09-15-2015, 02:06 PM   #15
everyone that I know that has upgraded from a TT to a fiver has went up in mpg, not down. probably due to the better aerodynamics of the fiver being tucked closer behind the cab
camperboy is offline   Reply With Quote
Old 09-15-2015, 02:08 PM   #16
As others have stated you are in for a pleasant surprise at how much better the 5er will tow. A couple of things to reinforce what others have said you are taller and be careful not to back up too sharp or the upper level of trailer will get into the corner of the truck cab. Also be sure you are latched in the hitch before raising legs and pulling off.
Steven & Tiffany
2015 Crusader 296BHS
2013 Chevy 2500HD LTZ CC Z71
Camp as often as we can
Steven379 is offline   Reply With Quote
Old 09-15-2015, 02:21 PM   #17
Fifth Wheel Towing
Originally Posted by blwnsmoke View Post
I was nervous just like you. Our first camper was the 40ft in my signature. I've towed TTs before up to about 27feet long and knew I wanted a 5th wheel. We almost went with a 42ft but I was nervous with the 40ft.. and then you fold down the bike rack in the rear which adds another 2-3 feet... I bought in MI and paid to have it delivered because I was too nervous to travel the 1,200 miles back home as a 1st time tow. I'll say now after towing 4 or 5 times, I have no reservations about traveling long distance any more.
I have to say, it tows like it is nothing. I get very little bounce at all and unless you are at a red like trying to start from a dead stop, you won't even realize you have a trailer behind you until you look in your rear view mirror.
The only thing that you need to be careful of is bends in the road. Sometimes I find myself forgetting the trailer is behind me and I get close to the white line when the road bends to the right and I look in my side view mirror and the trailer tires are almost off the road. But I have yet to have any issues at all with towing.
Heck every time but the 1st time I've had to back it down my driveway, I've been able to do it in one try which I'm really impressed about lol. I find the bigger the trailers are, they easier they are to tow, especially when backing up because you can't overcorrect so quickly (trailer is slow to respond one direction or the other). Try backing up a snowmobile trailer and you are constantly turning the wheel left, then right, then left, then right, then left, then right and then you found you've only gone back 20 feet lol.
Lastly, with a 5th wheel, you can turn your truck 90 degrees or close to it for some tight turns or U-turns. Can't do that with a bumper pull..
We were TT people and now we are on our first trip out with our 32' 2015 Wildcat. Installed is a Reese Goosebox, so that it would be compatible with the Flip Ball in my truck. The Goosebox has air chambers, where you can add air up to 50PSI. However, still feeling a bit of jerking as we pull. Is this jerking or bucking normal ?
TxBgWood is offline   Reply With Quote
Old 09-15-2015, 03:21 PM   #18
Iwannacamp's Avatar
There are times when mine "pulses". Kinda like brake on brake off etc. I blame it on the wind. I have tried to watch while towing(without dying) to see flex in the frame/pin box. I just assume it is air. It did it with a GN adapter and with the 5th wheel.
2017 Puma 297RLSS
Old 09-15-2015, 04:03 PM   #19
mud yapster's Avatar
If there's room to back it in and room to turn corners it's nice. Watch for low trees, low bridges, Hard to see back there in the dark backing ok during the day. Wind doesn't bother you like a TT does. Keep tires checked, make sure your Jack and lug tool fit, carry a road side safety kit with you.
Happy Camping. Taking ours for a 800 miles round trip Thursday.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 09-15-2015, 04:19 PM   #20
5thwheel's Avatar
Whenever I'm on a country road or in a park I constantly look for tree limbs near the side of the road and especially those over head. It's easy to hit those that are over head, luckily I've avoided them so far.
Congrats and enjoy it.
5thwheel is offline   Reply With Quote
towing
