Old 12-09-2015, 06:04 PM   #1
turn of inverter?
I just bought a surveyor 226rlds and it has the residential fridge. should I turn off the inverter when connected to shore power?
also should i use a pressure reducer on the black tank flush?
thanks
skytrash is offline   Reply With Quote
Old 12-10-2015, 07:01 PM   #2
no one?
Old 12-10-2015, 07:28 PM   #3
thanks
Owners manual?? Guessing, I would say it (the fridge) probably switches over to shore power automatically and turns inverter off.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 12-10-2015, 07:30 PM   #4
wmtire's Avatar
thanks
Are you positive your RV has an inverter, and you are possibly not confusing the term with converter?
I'm also not able to locate that model on the surveyor website. I saw a 266 RLDS and a 226 RBDS
http://www.forestriverinc.com/produc...6&ShowParent=1
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 12-10-2015, 07:36 PM   #5
mcnabbwr's Avatar
I have a different unit, however the inverter should operate the same. In mine it automatically switches between shore and battery power. I only turn it off when in storage.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 12-10-2015, 08:11 PM   #6
Bluepill's Avatar
Most factory installed inverters operate like this. They have an internal transfer switch that connects to shore power when it's available.
Get the make and model of your inverter, then let Google lead you to a factory manual.
Old 12-10-2015, 08:16 PM   #7
It's also quite common to have an external transfer switch. Either way, no action is required. It's automatic...
Karl4Cat is offline   Reply With Quote
Old 12-10-2015, 08:31 PM   #8
sorry, yeah its a 266rlds. i ask because the inverter does have an on off switch.
anyway thanks for the reply
inverter
