Old 10-02-2016, 08:12 AM   #1
cogito ergo moo
Cowracer's Avatar
Unclog a kitchen sink (MacGyver style)
What do you when your sink clogs and you don't have a plunger? I mean... seriously, how many people pack a plunger with them?
Grab an empty water bottle! The neck fits nicely in just about any RV sink. Stick the neck in the drain and squoosh the bottle flat with one quick motion. The blast of air will clear the clog in a jiffy. If you have a double kitchen sink that's clogged (like I did), make sure you put the stopper on the other side.
Tim
ID:	121907   Click image for larger version
FROG Member MO-0008-571 Since 2012
2016 Rockwood Signature Ultralite 8329ss7144444444444442121....My Project Blog: https://cowracer.blogspot.com/
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 10-02-2016, 10:08 AM   #2
Now that's a clever solution!!
Steve
4x4FF is offline   Reply With Quote
Old 10-02-2016, 10:55 AM   #3
SeaDog's Avatar
Neat tip!
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is online now   Reply With Quote
Old 10-02-2016, 05:28 PM   #4
Great idea... thanks!
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 10-03-2016, 01:42 PM   #5
Newly Retired
I have placed a screen strainer in my sink drain to keep food particles from going down the pipe. This is partly to avoid clogs but mostly to avoid spoiling food in my gray water tank. I know that sounds anal but hey I've got a 2016 RV for the first time in my life it's almost new!
Steveboe is offline   Reply With Quote
Old 10-03-2016, 01:49 PM   #6
jeff
jeff64's Avatar
X2 on the strainers in the sink drains (according to my DW).
McGyver water bottle trick is amusing, to say the least
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 10-03-2016, 02:20 PM   #7
bob213's Avatar
I agree with you on the strainer for the sink. Camp in 110* for a week and you will find out real quick that the bacteria in the grey tank can give off worse odor than the black tank in no time at all. We add the same toilet chemicals to the grey tank as we do the black just in smaller amounts.
I like the bottle trick...seem to always have an empty water bottle around.
You can avoid reality, but you cannot avoid the consequences of avoiding reality Ayn Rand
bob213 is offline   Reply With Quote
Old 10-03-2016, 08:06 PM   #8
Red face clogged sink
Had a clogged sink and all I needed was some pooring some boiling water down the drain, as over time some grease had begun to coat the drains. We had RV'er next to us who had tried many things and when she tried the boiling hot water her problem was solved. It might be worth a try of the bottle doesn't open it
anjb3741 is offline   Reply With Quote
Old 10-03-2016, 08:15 PM   #9
CZNEDY's Avatar
Cowracer, can you post a picture of your first attempt before you blocked the other sink?
2017 DYNAMAX Isata 3
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 10-04-2016, 09:27 AM   #10
cogito ergo moo
Cowracer's Avatar
Negative there, cuz... not my first rodeo. I knew better than that.
Tim
Rallies Attended:
sink
