Old 02-25-2016, 12:57 PM   #11
Rust proofing
Best product I have used is called fluid film
dustycreek2 is offline   Reply With Quote
Old 02-25-2016, 01:06 PM   #12
I have used POR-15 in the past on a street rod frame. It holds up great but I don't know if it can be sprayed I brushed it on.
offduty11 is offline   Reply With Quote
Old 02-25-2016, 01:21 PM   #13
Product can be sprayed easier to spray if thin down with vegetable oil fluid film does sell a sprayer to spray without diluting
Old 02-25-2016, 01:46 PM   #14
rubber lube was a silicon spray to stop sqeeks. you don't want to spray any oil on it because then you would have to power wash or steam clean to put any other product on it in the future.
j free is offline   Reply With Quote
Old 02-25-2016, 02:32 PM   #15
I have used Rustoleum rubberized undercoating and Rustoleum bed liner coating. Both come in spray cans and were purchased at Walmart. These cans spray a decent pattern and quite far to get up into hard to get areas. Shake the cans well and they will empty to the last drop.
Things to avoid: exhaust system; heat shields; brakes; steering joints; drive shaft; generator; yourself.
PenJoe is offline   Reply With Quote
Old 02-25-2016, 04:09 PM   #16
Delco Bobby's Avatar
Originally Posted by Total Bliss View Post
Has anyone done this and does it work? It is suppose to be a way to battle rust. What should be avoided when spraying?
Some toy and model train people use automatic transmission fluid on their train tracks. It is used instead of cleaning. The cleaning is done to allow better electrical contact between engines and the track. A little trans fluid wiped on the track in two or three places gets spread around by the train car wheels. That aids electrical conductivity so one can play instead of cleaning.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 02-25-2016, 04:22 PM   #17
3M makes a product that is made for that very use. That's what I would use.
Steve Ulman is offline   Reply With Quote
Old 02-25-2016, 04:26 PM   #18
Yes is a good way and better if you mixt IT WITH 20 % liquid tar . You can Also work WITH USED oil transmission , IT smelt Nothing . Would be better if dust and sand stick on IT because it will MAKE an more heavy layer protection . But THE BEST for me IS FLUID FILM PRODUCT. Go on internet and read about IT .
morinjean is offline   Reply With Quote
Old 02-25-2016, 04:51 PM   #19
Try this stuff. Works great, does not attract dust.
http://www.amsoil.com/shop/by-produc...-EA?zo=1203272
Matt Smith
2016 Coachmen Prism 2150LE
Johnston, Iowa
capav8r is offline   Reply With Quote
Old 02-25-2016, 05:34 PM   #20
Seriously doubt it, go with above suggestions.
pdqparalegal1 is offline   Reply With Quote
