Old 03-16-2019, 10:33 AM   #1
Vacate for the weekend
I own an E Pro 17RK that I use for work. I leave the camper for the weekend and was advised to turn off the water feed when not using for extended periods of time. My question is; will doing this damage any of the equipment such as the water heater or water pumps?
rlc1872 is offline   Reply With Quote
Old 03-16-2019, 10:38 AM   #2
I turn the water off every time we leave the trailer, even for the afternoon. I've seen only one (1) trailer where a water line separated. That was enough. Road vibration is insidious.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 03-16-2019, 10:45 AM   #3
Denver To Yuma In 90 Days
Yup!
After witnessing a couple of RV floods over the years at campgrounds...
I always shut the water off whenever I leave the camper.
All it takes is a slow dribble in the toilet to give you a very nice surprise when you get back from a day of sightseeing.
JohnD10 is offline   Reply With Quote
Old 03-16-2019, 01:47 PM   #4
bikendan's Avatar
Yup, turn the water off when we leave for extended time.
Equalizer WDH
Old 03-16-2019, 01:55 PM   #5
We turn ours off, also.
To answer your question, the only way it would hurt your water heater is if you drained the water heater and left it on. You are just turning off the water into the trailer. If you were to leave it long enough for the water to evaporate out of the water heater, that would hurt it, but just for a weekend, that's nothing.
The water pump, you aren't using anyway, if you are on city water. There should be no problem there.
merrykalia is offline   Reply With Quote
Old 03-16-2019, 02:18 PM   #6
Everytime I leave the trailer it is off. Same goes for the waterpump when we are dry camping.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 03-16-2019, 10:59 PM   #7
SailorSam20500's Avatar
Yup, turn off the water, water pump if running that way, and turn off the water heater (it doesn't take that long to heat 6 gallons of water).
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 03-17-2019, 12:00 PM   #8
We also turn off our water and waterheater overnight. It only takes about 10-15 minutes to get the water hot in the AM...
Joe & Sue - Camp Mutt Dazey
2008 Flagstaff Super Lite 26RKS
2008 Ford F-150
hotzfamily is offline   Reply With Quote
Old 03-17-2019, 04:01 PM   #9
Chris and Cecil
Turning off water when leaving camper
This is SO timely for us. We were wondering about turning off the water heater at the inside panel but leaving the suburban water heater turned on at the WH when we leave for the day. We use electric. Will that be okay or do we need to switch off the WH at the WH control switch in addition to the inside panel if we turn off the water to the tt? Thanks!
Dentist said I needed a crown.
I was, like, I know!
2018 Flagstaff Microlite 25FKS
2017 Dodge Ram 1500 EcoDiesel
Alabama Potter is offline   Reply With Quote
Old 03-22-2019, 01:45 PM   #10
I don't turn off my water heater at home when I leave for hours or even a couple of days. I don't turn if off in the RV, either. Is there a chance of a fire? Probably, but that's why I have insurance on it. I do turn the water off if we will be gone overnight. Again, that's why I have insurance on it. Is there a possibility that something will spring a leak, yes, but there is always the possibility that a meteor will drop from the sky and hit the RV. I don't stress the "what ifs" too much. I also don't take chances that don't need to be taken. Just use some common sense.
cat
