Old 06-24-2018, 08:07 PM   #1
very bouncy when setup at park
setup our new to us 2015 rockwood 8319ss for the first time this weekend. camp site was good and solid so we were able to get trailer nice and level and stabilizer jacks down on solid ground yet trailer was very bouncy when walking in it.
blasingame is offline   Reply With Quote
Old 06-24-2018, 08:13 PM   #2
How far did you extend the stabilizers? If they are 'fully' extended they begin to lose their effectiveness. Get some blocking and raise them up a bit. This should help with the bounce.
See you by the fire!!!
Steve and Stacy
sfelber9 is offline   Reply With Quote
Old 06-24-2018, 08:25 PM   #3
X2. I use chunks of 6X6 treated under my stabilizers. if you don't have front and rear you could add a set.
Kimber45 is offline   Reply With Quote
Old 06-24-2018, 08:47 PM   #4
bikendan's Avatar
Did you install tandem wheel chocks? That is the first step to reduce movement.
Equalizer WDH
Old 06-24-2018, 08:52 PM   #5
Put X-Chocks or Camco Wheel Stops between the wheels.
Put a stabilizer kit on the rear stabilizer jacks.
Add stabilizer jacks to the frame near the axles.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 06-24-2018, 08:56 PM   #6
What he said!
Have someone walk around inside the tt while you watch the wheels. Youíll see a lot of movement.
Old 06-24-2018, 09:04 PM   #7
woodyrock1's Avatar
Everything everyone suggested will get that bounce out, at least 95% of it. I have also noticed that when you get to campground, drop the stabilizers, chock the wheels (however you do) the tires are still hot and psi is up and takes a few hours to cool down and decrease in psi. As it cools and tires soften you can get a bit of play if using xchocks and might need to tighten them up a bit.
05 Ram 3500 Cummins Dually
14 8280WS Rockwood Sig. Ultra Lite
Prodigy 3 brake Controller
TST 507 TPMS
2017 = 30 nights /
2018 = 7 nights
woodyrock1 is offline   Reply With Quote
Old 06-24-2018, 09:24 PM   #8
B and B's Avatar
JT Strong Arms are the first and best way to stabilize. Second is the X Chocks. I tried it the other way first with my Rockwood. I have 6 point level up now and have tried the X Chocks, seems to help a little on this as well.
Good Luck!
Old 06-24-2018, 09:53 PM   #9
Nurek's Avatar
Did you left the tongue jack off the ground? I do and it helps. Just about 1cm.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
Nurek is offline   Reply With Quote
Old 06-24-2018, 10:08 PM   #10
bikendan's Avatar
Doing that would all the weight on the wheels and stabilizers! NOT good!
Equalizer WDH
