Old 04-14-2012, 06:59 AM   #1
Water Heater Drain
Sanitizing my FW system for the first time. When you do this, do you drain the WH? Is it the big nut in the WH access? I assume I'll have to drain when winterizing next fall.
Thanks! rick
2016 Chevrolet 3500HD DRW
2018 Rockwood Signature Ultra Lite 8290BS
bikeman911 is offline   Reply With Quote
Old 04-14-2012, 07:21 AM   #2
Triguy's Avatar
Thanks! rick
Your HWH should be drained and bypassed during winterization. You would drain by removing the anode (big nut). It's a good opportunity to inspect the anode at the same time.
You can just replace the old water that may be in there with chlorinated water by opening a hot water faucet and pumping the solution until you smell bleach coming out of the faucet. Probably about 6 gls so let it run awhile.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-14-2012, 09:40 AM   #3
the hwh is filled with chlorinated water. do you drain or just flush through the faucet?
Old 04-14-2012, 10:02 AM   #4
Triguy's Avatar
Either way will do the job but I drain because its quicker. After I drain, I flush the system until I don't smell bleach and then drain again unless I plan to camp shortly.
Scott
2012 Shamrock 233S
Old 04-14-2012, 10:52 AM   #5
TURBS's Avatar
I drain my hw heater after each use .
Old 04-14-2012, 11:23 AM   #6
I don't have a socket that size and it's tight. The low point drains by the galley seem to drain the tank, cause it seems like it takes time for the hwh to fill up after draining the system.
Old 04-14-2012, 11:41 AM   #7
The low point drains, may drain the tank. To find out for sure, put a bucket under them, and open. Measure the amount of water caught. It should be over 6 gallons. Would also help to open the faucet in the kitchen, hot and cold. Might want to open the "pop off" valve on the water heater also.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-14-2012, 11:45 AM   #8
TURBS's Avatar
Use a crescent wrench straight on to nut
Then take a screw driver to turn crescent
This WORKS
Old 04-14-2012, 06:26 PM   #9
MtnGuy's Avatar
It is probably not necessary to sanitize the water heater. The high temperatures should keep the microorganisms at bay.
That being said, I do sanitize mine.....people say that I am anal.
1 think that you need to consider is the water heater is a holding tank.....there is no way to flow all of the chlorine/water molecules in and out of the tank. Start with an empty tank to make sure it gets filled with the chlorine solution, and drain the tank before the fresh water flush.....again, there is no way to flush all of the chlorine solution out of the tank without draining before the flush.
Old 04-14-2012, 06:47 PM   #10
itch'n to road trip
campnqueen's Avatar
Send a message via AIM to campnqueen Send a message via MSN to campnqueen Send a message via Yahoo to campnqueen
We drain our water heater after each trip as well. Why leave water just sitting in there for a few weeks? Wouldn't it get slimy and smelly? We do not run chlorine thru the wh.
2012 Ford F-250 King Ranch Super Crew Cab 4x4 "Mae West"
2014 Work & Play 25ULA "Ula"
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
campnqueen is offline   Reply With Quote
Old 04-14-2012, 08:02 PM   #11
2007 WildCat 32QBBS
05CrewDually's Avatar
Water heater anode nut is 1 - 1/8" 6 point socket.
05CrewDually is offline   Reply With Quote
Old 04-15-2012, 06:46 AM   #12
MtnGuy's Avatar
Hmmm....mine is 1 1/16th on my Suburban.
Old 04-15-2012, 07:17 AM   #13
2007 WildCat 32QBBS
You are correct. 1 1/16" 6 point socket. Same as my lugnuts on my tv. My mistake.
