Old 05-03-2015, 08:02 AM   #1
DAF44's Avatar
Smile Water Heater Electric Magic!
I found an easy solution, at least for me, to turning on the water heater on electric without going outside or flipping the breaker on/off.
There is a remote control adapter normally sold to control outdoor Christmas lights that works like a charm. The specs for the adapter: 3-wire, 120 volts, 15 amps, 1875 watts. The specs for the water heater are 3-wire, 120 volts, 12 amps, 1440 watts. It's a match made in heaven. Just unplug the WH, plug in the adapter and then the WH to the adapter. Easy as pie.
In my TT the water heater electric plug is easily accessible under the sink cabinet. In some rigs it will be more difficult to access.
Now I can turn my water heater electric element on/off with a push of a button!
The adapter is the Stanley model 31171 (less than $20).
2015 FR Salem 27RLSS
2004 Dodge RAM 2500 Quad Hemi
DAF44 is offline   Reply With Quote
Old 05-03-2015, 08:11 AM   #2
wmtire's Avatar
Very interesting. The remote will work thru the cabinet without being line of sight?
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 05-03-2015, 08:18 AM   #3
DAF44's Avatar
I tried it first at home, works through walls up to about 60 ft.
Old 05-03-2015, 08:54 AM   #4
wmtire's Avatar
Cool deal. I guess it would be wishing for the moon for the remote to have some kinda indicator that it was on/off.
Looking at the product, you could plug some kind of light into one of the other outlets maybe, but would have to figure out how to run it out from the cabinet to visually see it.
Interesting
Old 05-03-2015, 09:00 AM   #5
DAF44's Avatar
The adapter has a red led light when it is on but it might be difficult to see inside a cabinet. Your idea of plugging in a light is awesome! I'll get a small 120v panel light and install it somewhere visible.
Great Minds Think Alike!
PS. About getting that 120v panel light, Where is my Radio Shack??
Old 05-03-2015, 09:58 AM   #6
mark0224's Avatar
Good Idea I have a couple of those laying around and right after Christmas you can get them for very little.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 05-03-2015, 10:19 AM   #7
DAF44's Avatar
Make sure you check the electrical ratings for the adapters. Looking online most of them were about 1000 watts. The Woods 3255 is 13 amps/1625 watts which is ok but the Stanley 31171 at 15 amps/1875 watts is the champ. The Suburban 6 gal WH is rated at 12 amps/1440 watts.
Old 05-03-2015, 11:47 AM   #8
Thanks for sharing
Wallace
twiggw is offline   Reply With Quote
Old 05-03-2015, 12:10 PM   #9
Flybob's Avatar
Not trying to cool off you water, but be careful that the guy next to you does not do the same mod and his remote turns on your WH when it is empty. The remote codes are not all the same, but there is a very limited number of codes.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-03-2015, 01:06 PM   #10
Sorry to rain on the parade, but don't really see a need for it as you need to, or at least I do, go outside and release the relief valve to bleed the air out of the tank and then just flip the switch to on.
electric, heater, water, water heater
