11-01-2011, 06:17 AM
Originally Posted by bruce10
Speaking of draining lines ...When you drain the water lines at the 'low point' uner the camper does it drain your water heater also? Winterirzed my camper and blew out the lines but did not pull the plug on the hot water heater to make sure it was empty. My camper is stored about 25 miles away. I have a Surveyor SP 189.
Empty the water heater (remove the plug ) and open pressure relief valve also.. if you can... take a few clean rags(12x12 ) ..twist a corner and insert them into the plug hole to absorb the water in the bottom of the tank..
11-01-2011, 06:20 AM
I watched the tech as he winterized my new 5th wheel ...The first thing he showed /told me was DRAIN the WATER HEATER !!!! Its a $800 dollar repair bill ...
11-01-2011, 06:43 AM
Lottery Non-Winner
It does not drain the heater. You'll need to pull the plug and lift the pressure relief bail to let air in so the water will gush out.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 572 |
| 120 members and 452 guests |
| 2011sv264, 2lvrvn, 4bnabird, 4Jeeperz, Adony, adp1326, ayotte, bayouboys, Bigmatt, bikeman911, bikendan, bka4tcu, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, carsonizik3, Cccross3, cgreen1509, chevy02, cllecr, crawford, cyclepuck, dashonthedash, dasimser, daw592, ddemme, DeeMax, dezolen, donh, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, Happy Campers 79, hark582, Hilgy, hjmiberry, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, jjhwisconsin, JJL, jking, johnthecamper, Jsroberts5, jsutherl, jtstromsburg, Kirby, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, MrAllen, mtfd515, mwilson949, ncgrl1, newtsx3, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, Sbbs2228, sbond, Sg6923, SinkorSwim, sjones7246, Smithee, snackage, sprayking, Stedman1, steeleshark2, Steve7575, sundawg, Swinks, Tekknogeek, tentcamper1, Terier, thehamguy1, thom01, Tincup13, tking1866, troyt, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer |
| Most users ever online was 1,025, Today at 01:04 PM. |
