10-10-2011, 08:07 PM
Brigitte
Water in lines
When done with trailer, (except for winterizing) in between trips or before driving, should I empty the water lines and the toilet of water or do I leave it all in except for dumping grey and black water? (this is about city water, not in the water tank)
Shasta Revere 21FBS LE
2010 Dodge Ram SLT 1500 QC 4X4 HEMI
Sheltie, Chihuahua and a Mr. Mutt
Kingston, Ontario
Days reserved 2012 (so far) 30 Days camped 2012:
10-10-2011, 08:20 PM
I don't drain mine. I wouldn't see the need unless the camper is going into storage for a long term timeframe.
 Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
10-11-2011, 06:47 AM
Lottery Non-Winner
I've never drained the lines except for winterizing. If I don't use the rig for a few weeks, I run the water for a minute or so to make sure all the state water is out of the lines.
I ALWAYS keep a little water in the black tank. Even after draining, I put a bit of water in there. Mostly because the toilet tank chemicals require it, but also to make sure that any solid matter that might have gotten missed doesn't become concrete.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
10-11-2011, 08:07 AM
too fast turbo sled
Hallways leave water in toilet bowl!
Keeps the seal lubricated.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
10-11-2011, 09:01 AM
Brigitte
Thanks to you all! Very helpful as always
Soooo
Does that mean that on route if stooping overnight at walmart or whatever we can just use the toilet?
Kind like in a bus ?
Also, the book says the tank needs to be 2/3 full before dumping. What if we are just out for the weekend? Don't bother draining or another idea is to add water in the toilet to fill and then empty tank? (I kinda like the idea of not hauling waste around)
Kingston, Ontario
10-11-2011, 09:45 AM
Moderator
Yes, adding water to the BW tank to 2/3 before dumping is the way to go. I also don't like to leave the tank partially full between trips.
Scott
DW, DD's x 3 and Murphy the Camping Dog - A Golden
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD, P3, Equal-i-zer
10-15-2011, 12:40 PM
Lottery Non-Winner
and yes it's exactly like on a bus.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
10-15-2011, 11:29 PM
too fast turbo sled
I only drain my hw heater every time we use it.
Ron and Amy Benhart
10-31-2011, 11:30 PM
Speaking of draining lines ...When you drain the water lines at the 'low point' uner the camper does it drain your water heater also? Winterirzed my camper and blew out the lines but did not pull the plug on the hot water heater to make sure it was empty. My camper is stored about 25 miles away. I have a Surveyor SP 189.
11-01-2011, 05:47 AM
I would go back and drain the water heater. When I drain mine I also flush it and leave the anode out, however others put their anode back in. However, this is a good time to check on the condition of the anode in case it needs replacing.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 574 |
| 121 members and 453 guests |
| 2011sv264, 2lvrvn, 4bnabird, 4Jeeperz, Adony, adp1326, ayotte, bayouboys, Bigmatt, bikeman911, bikendan, bka4tcu, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, carsonizik3, Cccross3, cgreen1509, chevy02, cllecr, crawford, cyclepuck, dashonthedash, dasimser, daw592, ddemme, DeeMax, dezolen, donh, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gb73071, gimp425, GlacierGus, greran, h20ski, Happy Campers 79, hark582, Hilgy, hjmiberry, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jiggerk, jimandjoyhamel, jjhwisconsin, JJL, jking, johnthecamper, Jsroberts5, jsutherl, jtstromsburg, Kirby, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, MrAllen, mtfd515, mwilson949, ncgrl1, newtsx3, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, Phil1, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, Sbbs2228, sbond, Sg6923, SinkorSwim, sjones7246, Smithee, snackage, sprayking, Stedman1, steeleshark2, Steve7575, sundawg, Swinks, Tekknogeek, tentcamper1, Terier, thehamguy1, thom01, Tincup13, tking1866, troyt, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer |
| Most users ever online was 1,025, Today at 01:04 PM. |
