Old 05-01-2012, 05:31 PM   #21
Herk7769's Avatar
Originally Posted by cootr68 View Post
Had windows closed. Had to open them to get smell out. Getting strong smell at the back side of w/h. And yes very dangerous. Is there a vent somewhere that could be plugged?
100% of the water heater's combustibles, from the propane jet to the exhaust are located outside. If it is getting inside check the caulk seal between the frame of the water heater and the wall.
I don't have a good picture of the seal between the camper walls and heater frame; but there should be one. If nothing else to keep the water from the safety valve out of the camper.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 05-01-2012, 05:40 PM   #22
cootr68's Avatar
Ok thanks I'll check that in the morning.
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
cootr68 is offline   Reply With Quote
Old 05-01-2012, 06:48 PM   #23
cootr68's Avatar
Ok not one to rest till something broken is fixed, farm boy in me I guess. Which picture represents where caulk seal should be?
1.
2.
3. Between styrofoam and metal
4.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 05-01-2012, 06:59 PM   #24
Can you get a picture of the whole water heater from the outside? Exhaust deflector could be bent, missing etc.
Old 05-01-2012, 07:03 PM   #25
cootr68's Avatar
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 05-01-2012, 07:14 PM   #26
In the last picture, that complete compartment should be sealed around each component to the back formed plate. Everything should have a grommet or be spotwelded to the rear formed plate. The entire frame should be sealed against the side of the trailer, no gaps, holes etc. If all this is sealed, I have no idea where the exhaust smell is coming from. Is this the first time you've fired up the heater in several months? If you are going to use it, make sure you keep some windows open. Maybe some a little ways away from the wh and definitely on the opposite wall.
Old 05-01-2012, 07:23 PM   #27
Herk7769's Avatar
Jeff,
My camper has a bead of RTV around the juncture between the outer sheet metal frame and the inner sheet metal frame. There is no way for fumes to get from outside to inside, except for a window close by.
I need to get a photo tomorrow and post it.
Old 05-01-2012, 07:30 PM   #28
cootr68's Avatar
Ok I got ya. The right and left side of the door frame housing are bowed leaving a gap. So when it exhausts it flows in the gap and back into the trailer. So I'll take that off try to straighten as much as I can and caulk with high temp caulk. THANK YOU ALL SO MUCH!!!!!!!
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 05-01-2012, 07:35 PM   #29
cootr68's Avatar
Ya Herk that is where the gaps are,between the two metal frames. I can almost fit my pinky finger in the gaps on each side.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 05-01-2012, 08:01 PM   #30
Herk7769's Avatar
Wow. I wonder how long that has been going on!
Any headaches (besides the normal ones) while camping?
Don't forget to caulk the floor too. Gravity will pull water into the Styrofoam wall under the heater when you drain it.
Old 05-01-2012, 08:04 PM   #31
If you can, sheet metal screw them together with sealant in the gap and then sealant around the whole perimeter.
Old 05-01-2012, 08:07 PM   #32
cootr68's Avatar
Ya gonna caulk everything. Haven't camped yet, bought it used in Feb picked it up in March. Just got around to the w/h.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
Old 05-04-2012, 03:21 PM   #33
cootr68's Avatar
Update.... got everything caulked all gaps sealed ........ no fumes!! Thanks for the help!!
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
