05-01-2012, 10:41 AM
water in water heater
I'm going to dewinterize today, I can handle that. Just wondering how long you can or should leave water in the water heater? Is it ok to leave it dry? (won't be used for about a month)
1997 Sierra m-27fls tt
1999 Pontiac T/A
2006 flstn Deluxe
2004 Polaris 330 magnum
Bear the Labrador
05-01-2012, 10:44 AM
The heater has been dry all winter, so another month is not going to matter.
As far as leaving water in the heater, I leave mine there during the entire camping season with no problems.
05-01-2012, 10:58 AM
Ok thanks mtnguy!!
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:02 AM
On the other side of the coin I drain mine after each use.
05-01-2012, 11:06 AM
I am just wanting to get the antifreeze out of it and wondered if i should leave water in it or drain it. Thanks Turbo
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:08 AM
I'm trying to avoid Herk I think he's about to bust a spring on the w/h today. Lol
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:14 AM
If antifreeze somehow got into your water heater, you will need to fill the water heater and drain it several times. Just running water through it will not thoroughly flush the heater. The you can just leave the water in it, or drain it until your next trip.
05-01-2012, 11:17 AM
CLASS "A" Senior Member
Shouldn't put antifreeze in the water heater. If you fill it you're buying at least 6 gallons of antifreeze you don't need. Use the by-pass and drain it to winterize it. If you have an anode rod the antifreeze will effect it.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
05-01-2012, 11:18 AM
Ok. When I went through the shakedown with the dealer he bumped the pressure relief and a little came out with the air. Leaking bypass I guess.
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:19 AM
Thanks, I really need to go down the basement and stabilize and clarify my home made Pinot Gris wine and label and seal the Petite Shiraz/Zinfandel I bottled last week today.
The day is half shot and I have not started it, yet.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-01-2012, 11:20 AM
Cootr, I'm not an old hat at this but I've never put antifreeze through the water heater, I just drain it and leave the anoid sitting in the hole, unscrewed. I antifreeze the rest (by closing the bypass lines). I also leave the water heater full during the time between outings. I don't think its doing any damage.
05-01-2012, 11:22 AM
I'll pull the rod I have a spare. And check the bypass valve. Correct?
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:24 AM
I would pull the anoid and shove a hose in there and flush the dickens out of it.
05-01-2012, 11:25 AM
Me too.
05-01-2012, 11:26 AM
I'd grab the logbook head down to the local airport rent a Cessna for 3 hours and let that sort things out. :-)
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 11:39 AM
Sorry, I am a professional.
Professionals get paid to fly; amateurs pay.
Oh man, am I JUST KIDDING!
05-01-2012, 11:50 AM
You have a point!!!! Lol I overheard a lady talking once she said her husband was a professional truck driver, guy behind me said under his breath to me "thank god he isn't an amateur!!" Lol
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 03:27 PM
Got everything squared away. Now when I fire the w/h I'm getting the exhaust smell in the camper. I have soaped and checked all gas lines no leaks no rotten egg smell. Only getting the smell when its heating. Wind kinda blowing towards the access door could that cause exhaust to blow inside?
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
05-01-2012, 04:46 PM
If you have the windows open you could be getting exhaust fumes into the camper. This is dangerous, if true, as you probably know. I would make sure the windows near the furnace and HW heater are closed.
05-01-2012, 05:06 PM
Had windows closed. Had to open them to get smell out. Getting strong smell at the back side of w/h. And yes very dangerous. Is there a vent somewhere that could be plugged?
1999 Pontiac T/A
2006 flstn Deluxe
Bear the Labrador
