Old 04-03-2013, 07:24 PM   #1
Water Pump Usage
Last week we stayed in a very nice state park that had electric only. We had plenty of fresh water in our tank for usage for the two days there. Should I leave the water pump switch turned on all the time or only turn it on as needed? I can hear it punp up the pressure every once in a while and did not know if I should turn the switch to the pump off when we are not using the water or just at night or if it does not matter. Thanks.
2013 Forest River Sunseeker 3010
RVFamily5 is offline   Reply With Quote
Old 04-03-2013, 07:28 PM   #2
No problem leaving it on all the time if you are not conserving battery power. But I definitely turn it off at night, as it always seems to come on just when I am drifting off!
bakken is offline   Reply With Quote
Old 04-03-2013, 07:30 PM   #3
If it pumps up without usage you have a leak. Youroo!!
Old 04-03-2013, 07:34 PM   #4
Barney1's Avatar
How often is "once in a while"?
If your water pump is cycling on and off two often it could be an indication of a leak in your water lines or a bad or stuck check valve.
My pump was cycling every 20 to 30 minutes - it turned out to be a loose hose clamp on one of water lines.
Barney
2020 Salem Cruise Lite 241QBXL
2016 Ram 1500 Big Horn Eco-Diesel
Previous Trailer -> 2012 Rockwood Roo 233s
-> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 04-03-2013, 07:38 PM   #5
Hi Barney1: The pump would only go off when we used a faucet or shower to pump up the lines. I just did not know if it would be ok to leave the switch on all day if we are hooked up to electric and have plenty of fresh water. i am new to rving and did not want to cause an issue by leaving it on all day.
Old 04-03-2013, 07:48 PM   #6
TURBS's Avatar
pump cycling with no usage sometimes means theres air in the water heater .
Old 04-03-2013, 07:51 PM   #7
Engineer of Crazy Train
ChooChooMan74's Avatar
I think it is actually a good idea. If it cycles a lot, then you know you have a leak and should get it checked.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 04-03-2013, 07:56 PM   #8
Once I am set up and camping I rarely ever turn mine off. I would say the amp draw unless the pump is actually running has to be next to nothing and wouldn't be worried about it.
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-10-2013, 10:03 PM   #9
OL Creeker's Avatar
Never saw a leak in our TT, yet the pump will cycle every 10 mins or less.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 04-11-2013, 08:26 AM   #10
If it's cycling like that, you have a leak! The leak may only be thru the check-valve within the pump back to the pump input, but it's still a leak.
