Old 08-29-2016, 10:52 AM   #11
Wolverine 1945's Avatar
Maybe a stupid question,,, but have you check the water faucet before it enters your unit ??? And maybe the hose you are using ???
GOOD LUCK !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-29-2016, 04:07 PM   #12
Fulltime family RVer
Originally Posted by jtstromsburg View Post
Have you flushed the washing machine lines?
This was my issue. I bleached the water system but neglected to sanitize the washing machine lines in the front closet because they're a hassle to get to. My problem came back within 2 weeks WITH A VENGEANCE.
We re-sanitized the system and made sure to get those. The moment my wife opened the tap up there, she almost threw up.
Eww, stinky water! Sanitizing the fresh water system. | Learn To RV
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 08-29-2016, 05:15 PM   #13
I would think if it was the camp ground water, all of the campers would be having this issue or at least in my area. There are about 12 campers on our line and only the Sierra's are having the issues. Hot and Cold water, so it makes be believe there is a flaw somewhere in our water lines. Something is not getting flushed properly. If you run about 15 - 20 gallons of water though it, it will be much better, but when you leave it for a few hours it is back. I've tried different filters, no filter, filter on the hose. Nothing seems to work. It would be nice if FOREST RIVER would step up and let us know how to fix this issue.
Denise13065 is offline   Reply With Quote
Old 08-29-2016, 05:20 PM   #14
I initially bleached the hose too and since that didn't help, I bought a new hose. Same thing. I have not checked the Faucet, but I will do that. Again, only the Sierra's are having this issue. There are about 12 campers in our line and 4 of us have Sierra's. ONLY the Sierra's are having the issue.
Old 08-29-2016, 05:22 PM   #15
I'm the only camper with a Wash machine and my water doesn't smell as bad as a couple of the other Sierra's. I'm trying to fix mine so it doesn't smell as bad as theirs.
Old 08-30-2016, 07:46 AM   #16
I would first make sure it is not a CG problem !!!
Stranger things have happened !!!
Again,,, GOOD LUCK !!!
Old 09-07-2016, 11:49 PM   #17
collinpr's Avatar
Okay, this past season in Yuma, had the sulfur smell bad. Did the bleach thing, helped very little.
Then occurred to me those water lines going to where a washer would be...
yep, opened those up and just about enough to make you puke. Loaded more bleach and ran thru the entire system. Presto fixed.
collinpr is offline   Reply With Quote
Old 09-08-2016, 12:15 AM   #18
Capsfloyd's Avatar
If you have a on board canister water filter, change that. Put on on the outside before water comes in
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 09-08-2016, 07:57 AM   #19
collinpr's Avatar
Yeah, got rid of the in line filter that came with the unit. Use external filters, no difference until I sanitized the whole system including the washer lines to the front closet.
I may install valves to close those lines off this coming winter season down South, no intention of having a washer in there.
My unit is a 365RL. Same issue at different parks.
Old 11-27-2016, 07:41 PM   #20
Hi
I'll tell you what I it is its not the water its the air vent under the sink for the drain, its bad and needs to be replaced. its a black vent on the top of the pipe coming from the drain pipe its not closing the air value to close of the smell. It does not have a pee trap. To drain the sink the vent will let air in the drain sink and close when no water is draining. Its bad.
Jerrymac is offline   Reply With Quote
camper, water
