Old 08-27-2016, 09:05 PM   #1
Water smells in Camper
I have tried bleaching the lines twice in one month, but nothing seems to help the smell. I am at a permanent spot and for whatever reason, only the Seirra campers are having this issue. The smell is worse at Kitchen sink and the in the Galley. I have to assume there is a flaw in the water lines since only the Seirra's are having this issue. Any idea or clues on what we need to do. My neighbors camper is so bad, and is a year newer than mine, that they can't even use the water without airing out the camper. I have a 2013 365SAQ and so do they. There are a couple other Sierra's at the campground and I asked them if they had a bad smell in their water and they do as well. My neighbor on the other side have no issues what so ever. So we are all trying to figure this out. Any help would be appreciated!!
Denise13065 is offline   Reply With Quote
Old 08-27-2016, 09:11 PM   #2
Carknocker Family
Ida Ratherbe Camping's Avatar
All water or just hot? Thinking you all have same water heater and anode in the heater having bad reaction to water makeup. Smell like sulfur? All I got.
Hope you get it figured out.
Nights camped 2014...26
Nights camped 2015...20
Nights camped 2016...20
2005 Dodge 2500 5.9 Cummins 6 speed manual
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 08-27-2016, 09:29 PM   #3
All water, cold water is worse then the hot water.
Old 08-27-2016, 09:31 PM   #4
W5CI's Avatar
Change anode rod and flush HW heater very well. That should take care of the Sulfur smell, since it's both hot and cold you must have bad water
2004 Cedar Creek 30RLBS MORryde IS/Disc Brakes
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29 2016 Days Camping 50
2017 Days Camping 8
W5CI is offline   Reply With Quote
Old 08-28-2016, 12:59 PM   #5
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by W5CI View Post
... you must have bad water
OP said only one brand of trailer in the park has this problem. Must be related to how the park's water is reacting to the Sierra's plumbing system. The on-board water filter maybe?
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-28-2016, 01:41 PM   #6
CaptnJohn's Avatar
Every camper I had with an onboard filter saw that removed in days. The inline hose filter is changed every 6 months of use. No leak problems and easier to get st as well.
Old 08-28-2016, 01:55 PM   #7
water issue
If the water source is high in minerals (well) it will react badly to the aluminum tank of the hw heater. Water will have a nasty sulfur smell and even turn blackish.
markb422 is offline   Reply With Quote
Old 08-28-2016, 04:57 PM   #8
DouglasReid's Avatar
The problem is obviously NOT the water heater, since the cold water is worse adn it never goes near the water heater.
It sounds like the source has compounds in it that you need to filter out prior to it entering your camper.
I would suggest getting a charcoal filter in a canister and hooking it up inline prior to the water entering your camper. The canister and filters can be had at Lowes, Home Depot or any of the Big Box stores. I would follow this up with a Camco in-line filter to complete the filtering process.
The charcoal should filter out the problem chemical or compounds and the Camco Filter anything not taken out by the charcoal element.
Good Luck!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is online now   Reply With Quote
Old 08-28-2016, 05:03 PM   #9
jtstromsburg's Avatar
Have you flushed the washing machine lines?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 08-28-2016, 07:32 PM   #10
I had a similar problem in Donna TX rv park. It was in the water line so now I run a little water out before hooking up. Tried all the bleaching finally had to let it sit and dry out at home. That solved the problem. My guess it was stale in the hydrant.
Dakota C Creek is offline   Reply With Quote
camper, water
