Old 08-17-2013, 07:18 AM   #21
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by mjones12 View Post
I have for years used the x-chocks exclusively as chocks with nothing else, and they work great. The trailer will not roll if they are installed and tightened.
There are two kinds out there. The BAL X-Chocks with the wrench-and-nut tightening system is a true chock (or so they claim). The Ultra-Fab Chock-n-Lock (which I have) sell for $30 a pair and are advertised as stabilizers used only to prevent the rocking motion associated with folks walking around in the trailer. They are lever operated. That's why I still use wedge chocks to prevent rolling; the C-n-Ls won't hold a TT that wants to go somewhere badly enough. (as I found out).
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-17-2013, 07:20 AM   #22
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Batts-toy View Post
Interesting, then they are saying 'not to use them as chocks' when un-hooking, so you use regular chocks to un-hook then place the x-chocks so the only purpose the x units are serving is as stabalizers (if you follow the instructions).
Exactly. Ultra-Fab's "Chock-n-Lock" is a stabilizer only.
Teach
Wright and Penny
Richmond, Va.
Old 08-17-2013, 08:58 AM   #23
Swaggler's Avatar
Originally Posted by lvnthenw View Post
I am curious what others might think of a technique I have been using this summer. I am using the plastic wedge chocks and this is on relatively level sites. I get situated/level and then put a chock up tight behind the front tire of the trailer, then put the truck in reverse and just put some pressure on the chock, then while still applying the pressure, my wife will slide another chock in front of the tire. Let the pressure off and the tire is wedged between the two chocks. My thought is this might achieve some of the desired effect of one-step or even a x-chock. What do you think?
I see the logic in this technique but it seems a little dangerous to me. Couldn't you accomplish the same thing by giving each chock a good rap with a mallet?
Always believe that you will ultimately succeed at whatever you do, and never forget the value of persistence, discipline, and determination.
Swaggler is offline   Reply With Quote
Old 08-17-2013, 01:19 PM   #24
AKA: 'tiredTeacher
awellis3's Avatar
I did that, but the wheel still rolled onto the chock afterwards. I cam to the same conclusion as lvnthenw, use the TV to seat the wheels onto, not just up against, the radius chocks.
Teach
Wright and Penny
Richmond, Va.
Old 08-21-2013, 11:57 AM   #25
Another rat in the race
jar3316's Avatar
One thing to remember about the X chocks. I found this out the hard way. If you put them on right away when you get where your going, don't for get to come back and check them later. The tires will cool and they WILL loosen up. We suffered no damage, but the trailer did roll about a foot back the next MORNING! Now, I know my DW has a mouth like a sailor, and I check them chocks and stabilizers every morn while I get up and walk around.
A rainy day camping is better than any sunny day at work
2004 F250 V10 SD Xcab 2011 Wildwood T26BHXL
jar3316 is offline   Reply With Quote
Old 08-21-2013, 12:51 PM   #26
Gizmo0706's Avatar
Very true, they do loosen after the tires cool so check them! AND they don't do well when put over tire covers for storage. I about lost a pair of undies when I found that out! My trailer rolled about a foot and slid off the 6x6 block the tongue was sitting on. I use the x-chock AND the plastic yellow chocks now.
Gizmo0706 is offline   Reply With Quote
Old 08-22-2013, 08:34 AM   #27
AKA: 'tiredTeacher
awellis3's Avatar
I hadn't thought of that. I'll wait to put them on since I'm relying on my plain ol' regular chocks to prevent rollaways.
Thanks,
Teach
Wright and Penny
Richmond, Va.
Old 08-22-2013, 08:50 AM   #28
MotocrossCamper's Avatar
How many pop-up owners have forgot to put down the stab jacks?
I did! Didn't realize it until we climbed into bed and stood the camper straight up and down on the bed!
MotocrossCamper is offline   Reply With Quote
Old 08-22-2013, 12:01 PM   #29
Fulltime family RVer
Happened to me in my buddy's pop-up. He setup in the rain and was rushing. Even better- he went to be first on the tongue side. Dad and I went to bed well after him and were awaken by the alien invasion at 5am when natured called my friend outside. Said he heard the crash midstream and instantly knew what he forgot...
Old 09-06-2013, 10:04 PM   #30
I just bought a 2011 Georgetown Forest River 28' MH - Is it okay when using the levelers if all the wheels on one side (front and back) are off the ground when it's leveled? Can I use it that way?
Ed
Ed Sorger is offline   Reply With Quote
