Old 11-20-2012, 02:31 PM   #11
Originally Posted by Dave_Monica View Post
No problem leaving the tank heaters on as long there's something in the tank...they're thermostatically controlled. As far as heat in the camper, you only want to ensure that the temperature inside doesn't fall below freezing, so whatever heater/setting you need to accomplish that.
Dave
Dave, I just redid my underbelly a month ago. I saw the tank heaters for the first time. They're nothing more than a sticky heat pad. Are they really controlled? I kind of regretted not to replaced the two damaged ones while I was there (tore apart by the rodents). Erwin
Erwin and wife and family of 4 little ones
St. Louis MO
2004 FlagStaff 8528BHSS BunkHouse 30 foot 5th wheel
1999 F350 7.3L PSD Superduty, Super cab, long bed, auto, Dually
1995 F350 7.3L PSD, stick, dump bed work truck
erwin is offline   Reply With Quote
Old 11-28-2012, 05:43 PM   #12
jtrader's Avatar
Mt wife and I are full timing it in Cincinnati. We have a 28' Grey Wolf TT and all we use to heat it is a 1500 watt heater. For your situation I would recommend leaving the factory furnace on with your cabinet doors open to keep the pipes warm, heat tape and insulate the main water line, and turn on your tank heaters. That should keep everything from freezing unless you get into some longer cold spells
jtrader is offline   Reply With Quote
