Old 02-24-2012, 02:37 PM   #1
Post weight dist. hitch
We own a 2012 Flagstaff D625. Tow vehicle is a 2003 Grand Caravan with a heavy duty tow package. The problem is that when hooking up the trailer, the back of the van sinks lower that I like to see. I want to add a weight distributing hitch which should help this problem. The trailer has dual propane tanks. Forest River tells me that I would have to go back to a single tank. I am a guy who does not want to believe in the term 'can't do it'. I go with the idea that where there is a will there must be a way!. Has anyone solved this problem and succeeded in using dual tanks with the WDH??
Hannes is offline   Reply With Quote
Old 02-24-2012, 02:55 PM   #2
MtnGuy's Avatar
Would a single spring bar setup work without having to remove a propane tank ??
Reese Light-Duty Weight Distribution System - A-Frame - 4,000 lbs GTW, 400 TW Reese Weight Distribution RP66069
Old 02-24-2012, 03:00 PM   #3
It just might, I will have to look into this possibility........ Thanks for the suggestion!
Old 02-24-2012, 05:47 PM   #4
Now a "Top Member"
EdJunior's Avatar
Dang Chap...I've never seen one of those before. Good find!
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
EdJunior is online now   Reply With Quote
Old 02-24-2012, 07:18 PM   #5
Please tell us why a normal WDH would not work with the dual propane tanks?
Jack
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
jackhartjr is offline   Reply With Quote
Old 02-24-2012, 07:32 PM   #6
sherdep's Avatar
Jack
Its a Pop up so the front maybe too narrow to facilitate the correct spacing that is needed and thats probably why Forest river told him only one tank to make it work.
I would think you could relocate the tanks if needed to facilitate this but without a picture of the front section it's hard to vision what he is dealing with.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-24-2012, 09:02 PM   #7
MtnGuy's Avatar
Ed, I remember seeing that a while back while researching some other type of WDH.
The length seems to be adjustable, so the there could be some tweaking to get it around the battery box and propane tanks.
Old 02-28-2012, 12:04 AM   #8
What about a Reese Mini 350? I think those are specifically designed for popups.
phone man is offline   Reply With Quote
Old 02-28-2012, 12:35 AM   #9
Drinkin beer on the beach
Rod Johnson's Avatar
My muffler shop also does all sorts of hitches and welding jobs. Your local place might, too.
Or... I picked up a Hobart 135 a few years back. Its a pretty simple and inexpensive MIG setup. Once you figure out how to stick metal together, a whole 'nother world opens up. And come on, now you have an excuse to buy more tools!
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
