Old 04-23-2016, 03:37 PM   #1
Iwannacamp's Avatar
Weight police??
I found what looks like a heck of a deal on this...
2013 Open Road 427bhs. It is about 12k dry...14+ loaded.
My truck says this...
Name:	ImageUploadedByForest River Forums1461443622.872883.jpg
It is supposed to 23k gross towing and about 6500# with me and some stuff in it...
I am wondering now if my 11500 gross was over weight.
Kinda lost. I remember the dude at the RV shop said my truck would pull anything on the lot and he had some big 5ers
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 04-23-2016, 03:45 PM   #2
BandJCarm's Avatar
What kind of truck? What is the payload?
This is a Ginormous fifth wheel, unless I have googled wrong. I show 17,000 lbs......triple axle, 3 a/c units, 5 slides, 42 feet long...... it'll take a truck with a massive payload to pull that thing.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 04-23-2016, 03:50 PM   #3
Oaklevel's Avatar
Attachment 105847
Be interesting to see what others say..... What rear axle do you have??? My 05 5.9 Dually is rated to tow 13,900 but I do not have the 4.11 rear gear.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 04-23-2016, 03:51 PM   #4
Iwannacamp's Avatar
My ole truck is a 2005 Ram 2500 4x4 4dr 6spd. man SB diesel.
The sad part is the cargo of...
Name:	ImageUploadedByForest River Forums1461444635.314108.jpg
To me. That is sad. Everyone knows the ole 5.9l will pull anything. Ha ha
2017 Puma 297RLSS
Old 04-23-2016, 03:53 PM   #5
BandJCarm's Avatar
That shows a Payload of 2,043 lbs. Unless I have the wrong trailer looked up, that big trailer must have pin weight around 4,000 lbs.........
FROG AR-0019-242
Old 04-23-2016, 03:53 PM   #6
Iwannacamp's Avatar
I have 4:10 gears also
2017 Puma 297RLSS
Old 04-23-2016, 03:58 PM   #7
Oaklevel's Avatar
Try here...............
Dodge Towing Guide - By Vehicle
These stats are my 2005 dodge truck :
2005 dodge ram 3500 pickup 3500 SLT, QUAD CAB, 2WD, 8.0 Ft Bed, 4-Speed Automatic Transmission, 5.9L High-Output Cummins Turbo Diesel Engine:
With 3.73 Axle Ratio Axle Ratio [i] You Can Tow 13850 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 11500 lbs
Payload [i] = 4513 lbs
Curb Weight [i] = 6987 lbs
Curb Weight Front/Rear = 4005 lbs/4005 lbs
GAWR Front/Rear [i] = 4750 lbs/9350 lbs
Gross Combination Weight Rating (GCWR) [i] = 21000 lbs
With 3.73 Axle Ratio Axle Ratio [i] You Can Tow 14200 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 9900 lbs
Payload [i] = 3250 lbs
Curb Weight [i] = 6650 lbs
Curb Weight Front/Rear = 3985 lbs/3985 lbs
GAWR Front/Rear [i] = 4750 lbs/6200 lbs
With 4.10 Axle Ratio Axle Ratio [i] You Can Tow 15850 lbs
Gross Combination Weight Rating (GCWR) [i] = 23000 lbs
With 4.10 Axle Ratio Axle Ratio [i] You Can Tow 16200 lbs
1966 Mustang GT
1986 Mustang SVO
Old 04-23-2016, 04:02 PM   #8
Oaklevel's Avatar
Yours ??? or close ???
2005 dodge ram 3500 pickup 3500 SLT, QUAD CAB, 4WD, 6.25 Ft Bed, 6-Speed HD Manual Transmission, 5.9L High-Output Cummins Turbo Diesel Engine:
With 3.73 Axle Ratio Axle Ratio [i] You Can Tow 13750 lbs
Payload [i] = 2788 lbs
Curb Weight [i] = 7112 lbs
Curb Weight Front/Rear = 4301 lbs/4301 lbs
GAWR Front/Rear [i] = 5200 lbs/6200 lbs
With 4.10 Axle Ratio Axle Ratio [i] You Can Tow 15750 lbs
1966 Mustang GT
1986 Mustang SVO
Old 04-23-2016, 04:05 PM   #9
Iwannacamp's Avatar
The info I saw..according to the dealer is 11850 dry and 2600 max. I told myself I could keep it lite and my truck supposedly had 23k gross and that would allow 13k+ for the trailer plus cargo of 3500 max and 6500 truck... And I could handle it....upgrade later. Bla bla.
I am now...after looking at the sticker I better stay with a pop-up or 20ft trailer. Kinda disappointed in the ole dodge.
2017 Puma 297RLSS
Old 04-23-2016, 04:09 PM   #10
Iwannacamp's Avatar
I wasn't smart enough to see how, but my truck is a 2500
2017 Puma 297RLSS
weight
