Old 05-07-2011, 09:20 PM   #1
Whaddya do if......
As I stand back and admire my new 2304s Rockwood Ultralite, and revel at how easy it is to raise and lower my power jack, I wondered what on earth I would do if, like so many other power items, it ceased to function. I retreated into my coach and pored through the bundle of warrantys and instruction pamphlet. Not a thing on the power jack. Does anyone know if there is a manual alternative to raising and lowering one's hitch if there is now power? I await input before I find myself powerless.
flugelboneman is offline   Reply With Quote
Old 05-07-2011, 09:47 PM   #2
kalik282's Avatar
You should see a plug on the top of the jack. Pop it off and use the supplied crank handle to raise/lower the jack as needed.
John
Probably not your unit, but, the instructions should be about the same...
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 05-07-2011, 10:25 PM   #3
Terier's Avatar
During the PDI I was shown how to use the crank handle just in case. I asked for the paperwork before heading home with the new TT. Upon arrival at the storage place the electric jack did not work.
As I went through my paperwork there were a couple of other things that I didn't have paperwork for like the anti-swag bar and spring bars. I called the service dept. and ask to get them. While they usually discard the papers but since they sell the items regularly it wasn't hard to get a copy. Of course it's a bit surprising that they just don't give you the papers to start with. The paperwork came in handy when I was seeking help from someone not familar with RVs.
Old 05-08-2011, 10:09 AM   #4
Depending on the brand of your power jack, the manual crank system may be as simple as the correct size socket (maybe an extended one) that you use with your own ratchet wrench.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 05-08-2011, 03:00 PM   #5
bikendan's Avatar
your dealer should have covered that during the PDI.
like others said, should be a crank supplied.
also, should be an instruction manual for it.
if not, go to the manufacturer's website for one.
Old 05-08-2011, 04:46 PM   #6
thx john and all the others. rubber grommet at top of jack reveals the crank nut, and found an extra crank handle. same size as leveling jacks. hope i never have to use it. great website to pick up all the things they dont tell you on the orientation. still have not found the manual slide opener. no indication on the chassis opposite slide of any acccess. i will try to contact forest river. also hope i never have to use it if and when i do find it.
