Old 04-19-2015, 07:54 PM   #1
What do you do if not using TT for 2 weeks?
What do you do to "temporarily" store your camper between uses. I won't be using it for a couple weeks. Last time I shut off the breakers and propped the refrigerator open. Should you disconnect the battery? IT was pouring down rain when I got back this evening and will have to go back tomorrow to shut it down for a couple weeks. I don't have power to hook to, but want to make sure nothing is ruined from sitting between camping trips.
Rhoadzie is offline   Reply With Quote
Old 04-19-2015, 08:04 PM   #2
Flybob's Avatar
I would add a battery shut off switch if you don't have one. It works best if it is between the battery pos terminal and everything else. In addition to eliminating the drain from parasitic draws like CO/propane detector, it prevents people turning on things like power jack lights etc which will kill battery. Just make sure to turn back on before towing or you will not have break-away brakes. I would also remove any food not in sealed containers.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-19-2015, 08:07 PM   #3
If you don't have time to install a shut off, just take the negative cable off the battery and shut the propane tank(s) off.
Old 04-19-2015, 08:07 PM   #4
asquared's Avatar
Ours routinely sits for several weeks between trips. Disconnect battery (or use battery disconnect switch if you have one) to prevent parasitic draw. Open fridge doors to prevent mold. We take food out but leave a few things like sugar (in a Tupperware container), salt pepper,cooking spray in. Drinks stay in unless they need to be refrigerated. Toiletries stay in. Turn propane off. Keep wheels chocked and landing gear down (tongue Jack in your case). We leave stab jacks up. If worried about ants spray around trailer. If you have an electric tongue Jack, we used to cover ours on our old tt.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 04-19-2015, 08:15 PM   #5
Recommendations for a battery cut off switch? Where do you mount it?
Old 04-19-2015, 08:20 PM   #6
gmeeker's Avatar
Battery disconnect, turn propane off, put all slides in. Any longer I empty fridge and keep it open to prevent mold growth.
gmeeker is offline   Reply With Quote
Old 04-19-2015, 08:32 PM   #7
Canadian Member
itat's Avatar
This:
https://www.bluesea.com/products/cat...tches/m-Series
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 04-19-2015, 08:37 PM   #8
trbomax's Avatar
I just back it up to the carport,unload the cart (because we use it daily here),plug it in, and do what ever PM is needed for the next run. From may to late oct we are never more than 5 or 6 days before we leave again,except on the 3 holiday week ends when we are ALWAYS home.Usual time out is 1 to 3 weeks,so it doesnt sit still long.
trbomax is offline   Reply With Quote
Old 04-20-2015, 11:34 AM   #9
Jestercyco's Avatar
Just cry!!!
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 04-20-2015, 11:56 AM   #10
ColoradoRick's Avatar
I also drain the water from the water heater....we've had that rotten egg smell from old water in there and never want that again!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
