08-16-2015, 05:32 PM
What is this stuff and how do I get rid of it?
I have these small black/dark brown raised dots all over the drivers side of my Sunseeker. I can scratch most of the bump off with my fingernail, but the brown dot underneath needs to be polished off. Trying to figure out what that are, how to get rid of them (without having to polish them off one at a time), and how to prevent them in the future....
08-16-2015, 05:44 PM
we get that if we park a vehicle under or within 20 ' of the choke cherry trees,of which we have many. Goo-gone will take it off but its a lot of work.
08-16-2015, 05:57 PM
Asphalt spray from the road?
08-16-2015, 06:02 PM
X2 and I would try with Goo-gone.....
Fonzie
08-16-2015, 06:12 PM
try a rag with mineral spirits or paint thinner and if they dissolve they are petroleum based...
I used to get them all over the white chairs around my pool, although mine were no bigger than pinheads. I blamed them on being 20 miles from the local airport, but we were far enough out that big jet planes turned while accelerating to fly much higher over my house. That happened 10 times a day. I figured it was some exhaust fallout of some sort. After having them for a few years, the airport built another runway, which diverted the traffic away from me and the dots disappeared for good.
2014 Shamrock 183
08-16-2015, 06:34 PM
Were they on there after a trip or just sitting in one spot?
08-16-2015, 06:37 PM
Looks like iron or tar deposits. Look up www.CarPro-USA.com there is a product called Iron-x and Tar-x. Spray it on and it will dissolve the iron deposits and rinse off. Also look it up on YouTube and check out the videos. I use it works excellent.
I have iron in our water that leaves iron deposits in our shower and it takes it right off. Professional auto car detailers use it also.
If you go to [url=http://www.CarPro-USA.com don't be surprised if you buy some other items also for your RV/Car finish. They have some of the best car products on the planet. No you won't find the stuff at any Wal-MART or Auto Parts place.. They have ceramic coating for your paint that's rated in years as to how long it lasts.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
08-16-2015, 06:49 PM
Just tried mineral spirits...no dice. I guess it's plant based?
08-16-2015, 06:58 PM
I have the same issue, mostly on the roof and drivers side of a PUP. I was thinking it might be from flies. I worked at it today with no luck. I'm afraid to try anything too harsh.
loumichelle735
Columbia Pa
2014 Rockwood 2318g
2010 Ford Escape
08-16-2015, 06:59 PM
I think I had the same stuff on my side wall. But the spots were only on the side where I had a post light in my driveway. Come to find out I was told by an entomologist that they were caused by some kind of insect at night. I tried everything to get the dots off but nothing worked. Then I made a watery paste using baking soda and water and I used that to rub the dots off. I then applied a couple of coats of gel coat wax to keep future "dots" from sticking. This is the wax I used :Meguiar's M5016 Marine/RV One Step Cleaner Wax....can be found on Amazon.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
08-16-2015, 07:03 PM
Try Iron-x from carpro-usa.com.
08-16-2015, 07:14 PM
If it is from bugs, always had good luck with a couple of dryer sheets soak in water.
08-16-2015, 07:30 PM
Fly poop. It can be washed off with soap and water and soft brush.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
08-16-2015, 07:49 PM
Cyber Phrenologist
I have these small black/dark brown raised dots all over the drivers side of my Sunseeker. ....
It's tobacco juice. Spit harder.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
08-16-2015, 08:05 PM
We have a problem with spider droppings where we live. The only product we have found that works is this a product called Drop Off. This stuff works like magic so I bought a case and handed out bottles to my neighbors. I don't think it's in many stores, but you can get it direct from the manufacturer or on Amazon.
08-16-2015, 08:20 PM
OK...tried tar remover...no good. Definately not tobacco juice! Showed up after being parked in the driveway for a few weeks...this is the side that faces the trees. Thinking something insect based. Does not come off with soap and water. I'll try dryer sheets this week...didn't think of that. It's not bug jerky, but doesn't hurt to try....
Thanks for the suggestions...if I find a winner I'll let you all know!
08-16-2015, 08:33 PM
try magic eraser or wd40 on a rag
08-16-2015, 08:35 PM
Also looks like fly poop to me.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
08-16-2015, 08:46 PM
Yep, fly poop.
08-16-2015, 09:48 PM
I would try Formula 409 cleaner or plain old ammonia mixed with water. Seems to work well on fly poop, but I have never tried it on an RV.
