Old 09-09-2011, 01:06 PM   #31
Herk7769's Avatar
Dave,
No offense taken. I just feel pretty good when I am down in the keys, where the closest RV dealer is 2 hours away and the closest parts warehouse is a day's drive, and I or my neighbor needs something repaired.
Items I have helped repair on site:
A broken awning that would not close
Rebuilt a Generator that would not start
rewired antenna coax connectors
Propane pigtail repair
Battery explosion in MH
Sewer leak due to cracked pipe
roof tear in a rainstorm
Well, I could go on but you get the idea.
HAM CALLSIGN - KC3FFW
Old 09-09-2011, 02:34 PM   #32
Problem Solver
sugarbear's Avatar
I would add a jack to change the wheels. I take along a 20 ton air over hydradulic jack to change the tires on my fifth wheel. It is small and I have no worries about a jack collapsing on me.
2007 Cardinal 362BHLE, Bogfoot Leveling System, Trailair Pinbox, Center-pointe Air Suspension
2014 Dodge 3500 MegaCab w/ 6 spd auto and air ride suspension
sugarbear is offline   Reply With Quote
Old 09-09-2011, 08:52 PM   #33
bend302's Avatar
Wow! Being a "Tool Guy" I love all these lists. I have to admit that I doubt I could use a lock pick set and would feel like a fugitive if I had one.
But, I saw WD40 on one of those lists. I am a bit new to this motorhome stuff, but I was warned that WD40 leaves a dirt attracting oily film that could attract grit to jack shafts, stair mechanisms or slide mechanisms that could cause problems. I was told to use a dry lube like silicon? Is there truth in that advice?
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is online now   Reply With Quote
Old 09-09-2011, 09:54 PM   #34
sherdep's Avatar
Bill
I would have to say yes there is truth to that - I use white lithium grease from a can on my stablizer jacks and have noticed dirt attracting to the screw part.
the WD-40 is usually used for door lock's - I have a door lock for the outside shower that tends to get stuck.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 09-09-2011, 10:00 PM   #35
Herk7769's Avatar
WD-40 stands for "Water Displacement Formula 40" It is a light water displacing oil used for just about everything involving quick slipperiness.
It does not "Lubricate" as it has no staying power and disperses quickly. It will "migrate" everywhere. Dry Lube like silicone or spray graphite is a better choice for slide mechanisms as you don't want an oily or greasy surface to attract dirt.
If you check that milk bin, in addition to a small can of WD-40 (for my fishing gear - it also makes a GREAT lure attractant because it is mostly fish oil), is a can of Slide Lube, Seal Lube, and Silicone spray.
Old 09-10-2011, 02:31 AM   #36
Glenn5995's Avatar
Much of our camping/traveling is in remote areas. We usually have no cellular phone service and resources can 50+ miles away. As a result if I want it fixed, it is up to me, so I carry a lot with me. My list includes, but is not limited to:
Sockets (SAE & Metric)
Ratchets & extensions
Wrenches (SAE & Metric)
Pliers
Hammers (small & sledge)
Hex keys
Torx
Nut drivers
Shovel
Ax
Pickaxe
Hatchet
Tow straps
Snatch straps
Chains
Snatch blocks
Jumper cables
Gloves
Clevis (hooks & D-rings
Breaker bars
Pry bars
Air compressor
Bottle jack
High Lift Jack
I could go on...but, you probably get the idea:
Here we are on Tuesday returning from our Labor Day camping:
As far as dry lube, I have used Slip Plate with good results:
SLIP Plateģ
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 09-10-2011, 09:46 AM   #37
sherdep's Avatar
Glenn - your box looks a little empty - thinks you need to add more stuff lol
I mounted my High Lift jack to the tool box to free up some space.
my tool box is as full as your's is - I also have a shipping blanket in my box so if I needed to lay on the ground I dont get too dirty.
Btw I am partial to Dodge's if you cant already tell - love the last picture too
Old 09-10-2011, 12:09 PM   #38
Glenn5995's Avatar
The picture of the toolbox is from a few years ago, the toolbox is actually even fuller now, as I have added more to the inventory . I have managed to keep my high lift inside so far. I have considered mounting it to the toolbox if I need to to free up more room in the future (possibly for a pull pal ), but I need to make sure my hitch will clear it in a left turn (that is when the release handle moves forward). I also have some packing blankets for that purpose as well. They are the white and orange items on the right side of the toolbox. While in the tool box they keep items from rattling and rubbing against each other.
We had a great time camping over the weekend. We like being off the beaten path!
