Old 09-04-2011, 09:44 PM   #1
What kind of tools do you carry?
I was wondering what kind of tools do you carry in your trailers?I am planning on carry assortment of screw drivers, channel lock pliers, hammer, adjustable wrenches, maybe a set of combination wrenches, socket set, wire cutters and crimpers, DC and AC volt meter.
Any other suggetions?
scottsman411 is offline   Reply With Quote
Old 09-04-2011, 09:52 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Depends on your definition of tools. I would add WD40 and duct tape. Do they count?
dimurrrw is offline   Reply With Quote
Old 09-05-2011, 06:42 AM   #3
Herk7769's Avatar
Weight of tools adds up quickly. I carried everything but a table saw my first trip and when I hit the scales I was shocked. After taking an inventory I reduced my tools and the camper weight by over 500 pounds.
This is still a work in progress. but here is our current checklist for our 3 month annual trek.
File Type: doc Camping Checklist - edited 15 June 11.doc (130.5 KB, 347 views)
HAM CALLSIGN - KC3FFW
Old 09-05-2011, 06:57 AM   #4
I carry just the necessary tools like a picknic screwdriver and a small set of other tools like a set of pliers etc. I have a small asst of screws in a small box. The most important item I have is a jack for my trailer and the right ratchet socket for the size of my bolts for the trailer wheels. The size is different than my truck. My wife takes care of the rest. I carry a few special tapes in case of emergencies.
capucine is offline   Reply With Quote
Old 09-05-2011, 07:10 AM   #5
I have the tools I normally carry in my truck (TV). A little everything, cheap little socket set, good quality #2 phillips and flat head, good Multimeter, connectors, etc..
Make sure you have an appropriate jack, I have a 12 ton bottle jack, lug wrench, and torque wrench with sockets to fit my lugs and WDH. Make sure you check to mske sure they fit and work when you need them. I put them in the TT on the right side where I can access them easy if I get a flat. 90% of the time you will pull to the right to change a tire. I don't want to put my blind back to traffic while digging in a compartment.
If I don't have a tool I need, chances are it is a tool that I probably won't use again, but can go somewhere and get it if needed. I don't want to carry something I will hardly use. All weight counts. Think about multi-tools like screw drivers where you change tips, wrenches with different sizes on each end, etc..
Just my thoughts. So far have always had what I need and often what someone else needs.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 09-05-2011, 07:35 AM   #6
Lottery Non-Winner
Ovair's Avatar
3 months every year? Jeesh, I'm in the wrong line of work!
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 09-05-2011, 07:44 AM   #7
jimh's Avatar
i'm going to have to make a list like lou so that i will know where it is...
i carry: a set of screw drivers
socketwrench
24" breaker bar
assorted sockets plus deep well sockets
assorted screws
1/2 doz fender washers
duct tape
hammer
hand saw
drill & bits
soldering iron w/solder
needle nose pliers
diagonal cutters
electrical tape
jack
assorted fuses
measuring tape w/level
spare sewer cap
spare sewer pull handle
multimeter
plug in circuit tester (abt 1.50 from harbor freight, checks for properly wired pedistle)
sealant and caulk gun
i carry a lot more than that, but that is what i consider most important..just need to inventory it and make note of its location.
the first time i had to change a tire on it , i learned to hate those decorative lug nuts. the wrench that i had used to check the torque them turned out to be slightly too big and twisted the cover around the nut when i tried to remove it. the nut comes out only slightly beyond the rim (if any) the rest is decorative. i carry deep well sockets that fit and will fit if the decorative cover comes off. (i have chiseled that cover off to get to the nut). breaker bar was needed when i couldn't move the nuts.
when i got rid of my 1st trailer, i had accumulated something to repair just abt every ailment encountered to that date. started fresh with the present one.
jimh is offline   Reply With Quote
Old 09-05-2011, 07:49 AM   #8
Herk7769's Avatar
What is that strange looking 4 letter word before the exclamation mark?
I seem to remember it but have not used it for some time...
The secret of success.
Invent something that costs a dime; can sell for a dollar; has low occupational risk; and is habit forming.
A no lose formula for money.
(No NOT drugs - Too risky)
Anything (not involving actual labor) you can do over the Internet so the boss has no idea where you are; and does not care as long as the deadline is met.
Old 09-05-2011, 07:51 AM   #9
Rugged Brown's Avatar
I will tail behind Lou from now on. If I need anything, he got it. that way, i don't have to carry anything.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 09-05-2011, 08:02 AM   #10
Herk7769's Avatar
No one has ever regretted camping next to me (that I know of!).
The reverse is not true.
