05-03-2015, 06:47 AM
What's your set up routine?
We pull up to the site, DW jumps out and goes to the electricity post. She is watching to make sure I go back far enough and there is room for the slide out.when I stop I check side to side level that's over the pin (5er). Pull forward a bit to lay down what's needed to get level, back up, chock drivers side trailer tires, hook up electricity, unhook from truck, level front to back. DW puts out slides, I hook up water,turn on water heater, put down rear stabilizers, check fridge is ok, get two chairs, two beers my lovely wife and say, "damn, I got it good." Everything else gets done in time.
05-03-2015, 07:10 AM
Sounds right to me buddy, mine would be Yuengling.
05-03-2015, 07:13 AM
I just joined the Forest River Forum, but have been on the road for two years. It has been wonderful without too many issues for a beginner, but learning fast. I enjoy these posts. Yes Tin can sailor.
05-03-2015, 07:15 AM
Cyber Phrenologist
1. Back into site.
2. Get out checklist notebook.
3. DO EXACTLY WHAT THE CHECKLISTS SAYS. IN THE ORDER IT SAYS TO DO IT.
4. Make sandwiches.
5. Nap.
And leaving is pretty much the above in reverse order.
I used to have a word doc of the checklist on another computer but that machine died long ago...
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
05-03-2015, 07:24 AM
My setup is the same as Radio's except step 5 for me is get a beer.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
05-03-2015, 07:30 AM
If I'm truly done driving for the day, the beer gets moved into the 2nd spot and all others moved down.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
05-03-2015, 02:11 PM
I am a little OCD on set-up and take down according to my DW.
When we arrive I walk the site first to see if this is level and or do I need to put boards out for the tires for leveling the trailer side to side.
I than back-up the vehicle and trailer or pull thru depending on the site we have.
She is positioning me as we park the trailer in the proper spot. Insuring that the water, sewer lines and electric cable will reach the proper spot for hook-up. She also checks to make sure slides and awning will clear all obstacle when extended.
I will than drop front legs and install x-chocks between the tires. I will than un-hitch the truck from the trailer; if we stay for more than a day.
I will then check the power pedestal for proper voltage and amperage. Then the power cable is attached with the surge protector installed at pedestal and attached to camper.
The 6-point level system will then be activated first, with the slides being extended after the legs are down. I will then finish up install the water and sewer lines.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
05-04-2015, 09:10 AM
#1- Find the correct site#
#2- Stop in the road and disconnect the toad, holding up any traffic
#3- Go back in the camper and use the restroom
#4- Get a beer on the way out of the camper.
#5- Walk the site while drinking the beer to make sure that all is working.
#6- Go back in the camper and get another beer.
#7- Try to back the camper into the site without spilling the beer.
#8- Try again to get lined up and back in again.
#9- Pull forward into the road and Try again to get lined up and back in again.
#10- If I made it, Go back in the camper and get another beer.
#11- Hook up the water and electric and cable and sewer.
#12- Go back in the camper and get another beer.
#13- Set out the chair and drink my beer.
05-04-2015, 09:32 AM
You forgot to mention you left the toad crossways of the road!
05-04-2015, 09:38 AM
#1 park the car in front of the trailer.
#2 unlock the trailer doors.
05-04-2015, 10:20 AM
I posted my routine in another thread last year:
Originally Posted by Kaadk
Preferred method:
1) Use levelling blocks/boards to level side to side.
2) chock with wedges.
3) Unhook from truck, level front to back.
4) Install X-chocks
5) Put out slide
6) Reconfirm everything level, tweak as necessary
7) Put down stabilizers
8) Hookup power, water, sewer.
9) Turn on HW
10) Put out awning, outdoor carpet, get out camp chairs.
11) Relax with cold brew.
Usual method
1) Screw it, it's level enough, chock with wedges
2) Unhook from truck, get front to back close enough.
3) Put out slide so DW can get kids ready for bed.
4) Hook up power/ water so kids can get ready for bed.
5) Pull out chairs, carpet etc... so bunk can be folded down so kids can go to bed. Chairs get dumped in a pile.
6) put down stabilizers in response to DW complaining the trailers too shaky. Stabs throw level off even further but slows down shake.
7) run and hide from wife on backside of trailer doing "that dang outdoor stuff." I.e. The rest of the hookups.
8) Install X-chocks cramped under slide out in the dark, and of course in the mud puddle, though it's been a drought for 3 weeks.
9) go inside, go to bed.
10) get up from bed, go back outside and turn on HW.
11) take dog for walk "since I'm up anyways" though I'd rather just crawl back into bed.
12) crash in bed
13) get up in morning and fix it all.
Pretty much still the same routine, only now it's 2 dogs instead of just the one.
05-04-2015, 10:43 AM
Kaadk's list seems most accurate to my routine minus the kids
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
05-04-2015, 12:00 PM
1) Do a site walk
2) Back in and use leveling lego blocks as required
3) Install 4 rubber chocks and 2 X Chocks
4) Unhook from truck, level front to back.
5) Lower rear stab jacks and deploy Strong Arms
6) Power
7) Slides out
8) Rake site as required/Put down Awning map
9) Turn on HW and Water Pump
10) Awnings out, chairs out
11) Set up satellite dish
12) Set Up outdoor cooking Area, RVQ, Propane Coleman Table etc
13) Remove bikes from top of truck
14) Cold coke or water! Relax
Our setup is in 95% in Provincial Parks/Conservation areas. Only Hydro. The average setup at site for both of us is 1 hr. We timed a full tear down yesterday with water as well. 45 minutes all in.
B and B
05-04-2015, 12:19 PM
After TOWTA ok'd the placement, the first thing I do is plug in and verify electric is good. No need to drag out anymore than that if power is not up to par. After that it gets unhooked and I finish sewer, water as the auto level takes over. Finish with slides and chairs, done deal. All takes about 6-7 minutes.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
05-04-2015, 12:37 PM
Canadian Member
I can only add a couple things to the previous posts....
1) After we arrive at the site and pick the best place to sit the TT (if its a back-in site), and before worrying about getting perfectly leveled, I would take a minute to check the electrical outlet at the post. No sense going through the whole routine only to find out there's a problem with the electrical hookup. DW refuses to camp without electrical hookup so it better be working!
2) My 3 DSs are between 15 and 20, so they all have a few jobs they are responsible for during setup and tear down. Makes it a lot faster.
05-04-2015, 12:53 PM
Mine is simple:
1) back in
2) open beer
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
05-04-2015, 12:58 PM
It's also good to check to see where the sewer drain is...sometimes it's 20-feet or more from the power connection which can make a one have to move the whole trailer so that your stupid sewer hose will reach.
(Not that I may or may not have actually done that...more than once or twice!)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
05-04-2015, 01:07 PM
Get this and your setup will be even faster!
http://www.amazon.com/Andersen-3604-...dersen+leveler
These babies hit the forums early last camping season and they are AWESOME! I have a level on our 5er Pin as well so leveling is dead easy now!
Caveat: some folks rigs have closely spaced axels and the Andersen's have to be cut down in order to fit between the tires (east to do if you have access to a band saw)
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
05-04-2015, 01:09 PM
YOU'RE DOING IT WRONG!
We pull up to the site, DW jumps out and goes and gets 2 beers.....
the rest is just details
05-04-2015, 01:10 PM
X2 - we keep our Progressive Power Management in the truck with us and once on site, 6 Actual makes a beeline to the power pedestal, plugs in the PM and gets immediate feedback that not only is there power but it is CLEAN power
