Old 02-17-2015, 02:31 PM   #1
Longhorn 105's Avatar
WiFi
Looking for some Ideas for picking up WiFi signal in campgrounds when their signal does not cover the entire campground
Mike & Patty
2014 Ram 3500 Longhorn 6.7L 4x4
2015 Columbus 320RS
Days Glamping 2015 - 13
Longhorn 105 is offline   Reply With Quote
Old 02-17-2015, 03:27 PM   #2
BooBoo23's Avatar
Get a hi-gain WIFI antenna that will plug into your USB port on your laptop. Here is a Ebay item # to check: 311019577037
It is a Kasens N9600 WIFI antenna with 80dpi gain which is VERY strong. Should pick up signals a couple miles away. It may be directional so you may have to try to point it in the direction of your source. If you check Ebay you may want to search around for the best price as it varies several dollars. There are other Hi-gain antennas available just make sure it will plug into your USB port.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 02-17-2015, 03:43 PM   #3
KyDan's Avatar
Go to Amazon and search for USB wifi antenna.
There are many to choose from.
Some have decent reviews so they must be seeing improvement.
Good luck!
Peace!
Dan & Rita D
Old 02-19-2015, 10:28 PM   #4
Boo boo, do you have direct knowledge of the unit you discuss. It would be nice if RVers would explain the equipment set-up they are using and the performance expierenced. Nothing rings truer than actual feed back from fellow RVers.
Old 02-20-2015, 12:12 AM   #5
BooBoo23's Avatar
I have not personally used a signal amplifier that plugs into a laptop. I am a ham radio operator and we are experimenting with hi-gain antennas that attach to a router that is plugged into the laptop. We are looking to transmit over several miles and use them for emergency communications with devices that have low power consumption since everything could operate from a battery. We are using modified routers that have a firmware change to operate at higher power allowed by FCC regulations. We could potentially operate at over 100W of power but we can't contact anyone that can't send a good signal in return. My current antennas have no amplifier other that the gain produced from the antenna (20dbi). I plan to get a WIFI antenna to work with my laptop so I can't give you any other information. Cost seems to be minimal so give it a try. The only thing that separates the men from the boys is the price of the toys.
Just do a Google search for "laptop WIFI signal booster" or "WIFI booster for RV" (almost 350,000 hits) and there is a lot of information. Read the reviews. If you use an external signal amplifier you will need to disable the internal one in the laptop or they will be in conflict. I liked the one I mentioned because it is an outdoor antenna, with 25' of coax cable and is 80dbi gain. They are claiming a 3000 meter range which is just a little over 1 3/4 miles (that would be under perfect conditions). They say it is weather proof but I wouldn't hang my hat on that either. It is 6600mw of power (6.6 watts) which is pretty strong since the laptop signal is less than 1/2 watt, probably more like 100mw of output. I read one of the reviews from someone that was using it in a RV park and said without the external antenna he would have no signal.
WIFI is a VHF 2.5ghz signal so it will work best when there is a clear line of sight to the source. That is why an external antenna is best because you can position it so your RV won't block a weak signal. If you could place it on your roof it would be great. I seem to recall of some that mounted a permanent WIFI antenna on the roof of a MH. Another source of information might be to do a search "WIFI" on this forum, not a lot there but may help. Since you are new to the forum, the search box is on the line at the top of the page that starts with "portal" on the left side. The big search box a the very top is for Google and that won't address RV's.
I'm sure there are full timers that use signal amplifiers all the time but just a chance they will be on the forum. I have been satisfied with WIFI reception so far and don't need to be on the internet every day but anticipate getting the signal booster.
KT4W
Old 02-20-2015, 12:24 AM   #6
Pretty much the "go to" among a large number of full-timers is the WiFiRanger.
They basically have 3 different wifi solutions. The main difference from other basic antennas is that those are actually routers.. providing a layer of protection("safe surf") when you're on public wifi.
rana is offline   Reply With Quote
Old 02-20-2015, 12:34 AM   #7
BooBoo23's Avatar
That is true a router will give an added level of protection. The modified routers we use can't be hacked. Others can see the signal we put out but can't connect to it without proprietary software that we use for ham communications. We have tried with other computers, laptops and smart phones but no luck.
I would be interested to see if the software with the external antennas has any encryption.
The WIFI Ranger has 1W output and has a 6dbi gain which is fairly standard with a lot of routers. The advantage is it can be mounted external to the RV and can be mounted high enough to get a good signal. The higher the better.
Wow, $360. You could buy a used Linksys router on Ebay for about $25 and a omnidirectional external antenna with 20dbi gain for another $8, 20' of coax for $20 and have more power. Someone on the forum has done that, I saw it in a search.
KT4W
Old 02-20-2015, 01:23 AM   #8
How powerful of a transmitter would something like that have?
Old 02-20-2015, 09:38 AM   #9
BooBoo23's Avatar
First I want to make a correction. The frequency of WIFI is 2.4ghz not 2.5ghz.
As far as the power of a Linksys router it is 15dbm or 32miliwatts. The power is achieved from the gain (20dbi) of the antenna which will give it an equivalent power of a little over 2watts. With a standard 6dbi antenna on the Linksys modem it would be about 1/2 watt output. There are ways to increase the output of the Linksys WRT54G modem. The FCC says WIFI must be limited to no more than 4 watts total output, transmit power and antenna gain combined, to prevent interference. For each 3dbi of antenna gain the output power is doubled. So the WIFI Ranger is at the max allowable output equivalent of 4 watts since it has a output of 1 watt and a 6dbi antenna.
BTW, when using an external WIFI antenna it may be required that the coax you use should be RG316 with a RP.SMA female plug (reverse polarity) on one end and a RP.TNC male plug on the other end.
KT4W
Old 02-21-2015, 02:47 PM   #10
BooBoo23's Avatar
Trying to get more information on the Kasens N9600 but don't find enough to satisfy me to want to purchase as yet. I would like to see a few reviews but don't find any. Nothing says if it will work with Windows 8. I think I will just use a router hooked with Ethernet cable to my laptop and use a hi-gain external antenna for the time being and if needed add a bi-directional amplifier. A router will also offer a safety factor with encryption. I've got several routers that I am not using so I can pick and choose.
KT4W
Old 02-21-2015, 03:09 PM   #11
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
Check out Technomadia | Adventures in Nomadic Serendipity They are full timers and the most knowledgeable people that I know on the subject.
Eaglelover is offline   Reply With Quote
Old 02-21-2015, 10:53 PM   #12
BooBoo23's Avatar
I downloaded the Mobile internet Handbook 2015 edition for my Kindle. Not a bad price at $6.99. Just starting to digest it.
KT4W
Old 02-21-2015, 11:29 PM   #13
Eaglelover's Avatar
WiFi
That's great. Subscribe to their RSS feed. They do a weekly video podcast and they will keep you up on the latest info.
Old 02-22-2015, 12:36 AM   #14
BooBoo23's Avatar
I'll check it out.
KT4W
Old 02-22-2015, 09:26 AM   #15
BooBoo, do you know why it seems to be looking for a needle in a hay stack, when your looking for a system, router and hi gain antenna, to boost your wifi signal having an android o/s on a tablet. Seems to me since tablet sales have outpaced laptops, you would think there would be equipment for that application.
Do you have any expierence in this area. Thanks
Old 02-22-2015, 10:52 AM   #16
WestCoastRV'er's Avatar
Good write-up for DIY WIFI Repeater:
diy-wifi-booster
First camping trip this year I was able to test out my new WIFI setup. Could not connect directly from my laptop.
Linksys WRT54G flashed with DD-WRT
SUNHANS 2 Watt 2.4 Ghz Booster with 6dbi attached antenna
This allows for multiple devices to be connect to WIFI. All I have to do is connect to my router and scan for available WIFI and connect. After that all devices can connect to internet via my repeater. No changes to devices.
Plans to add external antenna for better signal.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 02-22-2015, 10:53 AM   #17
Engineer of Crazy Train
ChooChooMan74's Avatar
I am putting a Ubiquiti Bullet on my Roof, and a Wireless Access Point inside the camper. Hope the high powered radio and high gain antenna will be a good match.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 02-24-2015, 04:35 PM   #18
Broken Toe
Cowracer's Avatar
I have long since given up trying to get Wifi out in public. Usually the coverage is spotty, and there are so many users that its slower than molasses in january.
I am grandfathered in on AT&T's unlimited Data Plan. I use FoxFi to tether my phone to my laptop. Works great, even underway.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 02-24-2015, 05:01 PM   #19
diy-wifi-booster
That is the best i've seen on the subject. Sure would be nice if someone in FR who is more sauve than I, tries it out and see what results they get. I'd need a little hand holding I think to get that up and running
Old 02-24-2015, 05:11 PM   #20
So choo choo, what will the cost be approx. and let us know if you gain better wifi access, thanks.
