Old 07-26-2017, 05:18 AM   #21
ARLO
Originally Posted by wherewolf17 View Post
To turn the water heater off? I tell myself to tell Google to set an alarm when I turn it on but then I forget to do that too. I wish it had a light that stayed on. It's hell getting old.
I install the lighted switch right by the door that is lighted so whatever we can leave the camper we can see inside we can shut it off that's helped a lot.
rlocicero is offline   Reply With Quote
Old 07-26-2017, 07:54 AM   #22
Wolverine 1945's Avatar
Check Lists are Great !!!
I guess FlyBob is not telling where he got the Red Tags ???
LOL !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-26-2017, 08:04 AM   #23
LOL !!!
Here are a bunch of places that have them.
Remove Before Flight Tags
Google is your friend!
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 07-26-2017, 08:30 AM   #24
Thanks Picker !!!
5 @ ebay for less than $3 ???
Old 07-26-2017, 07:43 PM   #25
Will the water heater work when switched to electric when on battery power or does it need to be plugged into shore power?
kollinr is offline   Reply With Quote
Old 07-26-2017, 08:22 PM   #26
Shore power only (or propane).
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 07-26-2017, 09:59 PM   #27
dbledan's Avatar
I forget something new every trip. I usually figure it out. Most times it has not cost me too much. Only once was it over 100 to fix...i get into a routine but each time there is something just a bit different...either no water and I am on the tank or no sewer and I am not. Once no power and another forgot a chock. Another time a storage door. Lots of walking around helps now too. I still forget but I catch it before I leave now.
dbledan is offline   Reply With Quote
Old 07-27-2017, 06:48 AM   #28
List are the best way I think to go !!!
We start a list of things we need to do & want to take,,, weeks before we plan to leave,,, we normally add some thing to it most every day,,, we keep the list from the trip before we use that to start our new list,,, we also keep a short list in our unit,,, when we are out and find something we want for next trip we add it to the lists !!!
Sorry to say but we have lists & notes every where,,, but we forget less than our kids do !!! Using lists & notes should be added to the 3 Rules of Getting Older !!!
LOL !!!
Old 07-27-2017, 07:18 AM   #29
ben31's Avatar
Originally Posted by Flybob View Post
I added this to the shore power plug when Plugging in. Reminds me to turn water heater off when unplugging
These work very well for a lot of things. We put up those little 3m command hooks at each place we needed to make sure we took care of, before we headed out and place one of these at each of them, as we turn them on, unhook them, etc. We also place one on the antenna crank as we deploy it upon arrival. Then leaving, we take the tags off of the hook as we stow, turn off, etc. We know we have 5. Before we lock the door, we count the tags and if we don't have 5 on the large hook inside the door, we know we forgot something.
If you have a driveable RV, you can use these, or the strips, which wrap around your steering wheel. You don't have to count those, you put the strip on your steering wheel as you set whatever up, then when you are leaving, you remove the strip as you stow whatever.
For the Tags https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
For the strips http://www.rvminders.com/
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 07-27-2017, 07:31 AM   #30
There was a member a while back that hung his keys on the antenna crank so he would not forget to put antenna down before they left !!!
I thought that was a GREAT idea !!!
Old 07-27-2017, 08:01 AM   #31
Put a switch inside. (Replace the crappy RV 120VAC outlet that the WH plugs into with a real electrical box and a real 120VAC outlet.)
ID:	146205   Click image for larger version
ID:	146206   Click image for larger version
ID:	146207   Click image for larger version
2011 Traverse LT, 3.6L, FWD
Old 07-27-2017, 08:07 AM   #32
Yeah that's the thing. I used to be a pilot and had the check lists. But that was life or death stuff. Most of this stuff isn't. I could probably drive around with the antenna up 90% of the time and it wouldn't matter. My worst screw up so far was leaving a deck chair leaning against the rig when I let the jacks down. The chair got caught on the generator door hinge. Luckily for me the hinge was stronger than the chair and bent the chair. Imagine if it ripped the hinge off. What a mess. Now I always walk around the coach before I retract the jacks. I won't be forgetting that one soon!
wherewolf17 is offline   Reply With Quote
Old 07-27-2017, 08:10 AM   #33
A32Deuce's Avatar
Circle check is the best you can do. Can't miss/forget anything if you always do a circle check. Even works for everyday driving!
A32Deuce is offline   Reply With Quote
Old 07-27-2017, 08:21 AM   #34
Not sure about the antenna thing,,, we might make it a mile down the road before it got RIPPED OFF !!!
Old 09-03-2017, 11:11 AM   #35
Potatoes chip bag clips on the steering wheel work great. You can write on each one what you need to check before you take off. Of course you have to remember to put them on the steering wheel!
2004 Georgetown XL 370TS
funmoneypit is offline   Reply With Quote
Old 09-04-2017, 08:19 AM   #36
Post it notes everywhere !!!
LOL !!!
Old 09-10-2017, 06:45 AM   #37
paulmac's Avatar
Originally Posted by Mdaniels4 View Post
Put a label on the door so when you lock it up to leave its right there in front of you to remind you.
I have a small check list above the door on the inside that I use before closing the door and locking for the last time before leaving a site. Some of the items are:
TV Antenna down
Vents closed
Hot water heater off
Refrigerator to gas
Microwave secured
Oven pilot light off
Stove burners all off
Heat / AC turned off
There are more. It is just a typed up list of things to remember. Cut down and placed above the door(you could even put it in a small frame and hang it near the door) Since DW does some of the things and I do others. One of us will read it out loud so we can make sure we got everything.
paulmac is offline   Reply With Quote
Old 09-10-2017, 09:32 AM   #38
The way we do it is the wife secures the inside & I do the outside !!!
We also make sure the dog in inside !!! LOL !!!
This time the wife was not sure the Toilet lid was closed,,, so after we hit the road she had to climb to the back and check !!! Just one more thing to remember !!!!
Old 09-10-2017, 10:05 AM   #39
Flybob's Avatar
I use these on the awning knobs and the Power cable ( reminder to turn of elect WH). Available in many sizes, I use 8" version.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-10-2017, 08:44 PM   #40
King of the Road
So does mean that now that we're old, the lights aren't on???
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
